Another DAMN PROBLEM! VTEC Oil Pressure Switch!
Old Jun 7, 2006 | 11:37 AM
roadracer321's Avatar
Default Another DAMN PROBLEM! VTEC Oil Pressure Switch!
I got a B18C GSR motor, and its OBD2. Supposively they did away with this VTEC oil pressure switch on my motor, and I am going to run the OBD1 P72 ECU which requires this sensor. How am I suppose to hook this up now? Do I need to buy a new OBD1 VTEC solenoid or is there a way around this? The solenoid is $350, and the sensor is $80. I dont want to pay this if I dont have to. Anyone with any ideas about this?? I believe it is suppose to be here.
Old Jun 7, 2006 | 12:49 PM
delacampos's Avatar
Default Re: Another DAMN PROBLEM! VTEC Oil Pressure Switch! (roadracer321)
you have the solenoid already, you just need the pressure switch. i couldn't see the plug for it in your pic though. it's only 2 wires and 1 of them is a ground. the other goes to the ecu. D6 is the pinout, i believe.
Old Jun 7, 2006 | 01:32 PM
I know I have the solenoid, and I know I need the pressure switch. You dont see it there, because its not there. Its 2 wires, blue and black, but I have to run them from the switch to the canon plug, and the black to the ground. My problem is, I dont know if there is a way around not using this switch and faking the ECU out to thinking there is one there, or if it will be easy to just drill and tap a hole and screw the switch in.
Old Jun 7, 2006 | 02:48 PM
jdmsiR20's Avatar
Default Re: (roadracer321)
you have a couple options:
1. pick up a used vtec solenoid with pressure switch and plug from the boards (no more than $80)
2. pick up a chipped ecu that has the pressure switch disabled.
3. bypass the pressure switch via this method:
pinouts:
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue D6
VTEC Ground Black Chassis Ground
from the ecu, take the wire blue (d6) and splice it into yellow/green (a4). this method tricks the ecu into thinking the oil pressure sensor is on board and well. proven method for both my previous cars, as well as h-t.
Old Jun 7, 2006 | 05:38 PM
how dangerous is option 3?
I have to buy an ECU anyways, so this may be an option. But, I would think option 1 would be the best one if 3 is too dangerous.
Old Jun 7, 2006 | 07:48 PM
ekb16's Avatar
u can tap the hole where the switch is suppose to be and just put in a diff. switch...or get a use b16 soleioid wit the switch...gsr jdm doesnt come wit the psi switch..mine was the same also but lucky i had a b16 head layin around so i just switched it..
monkeymk2
Feb 26, 2019 10:49 PM
EG type GTR
56
Oct 25, 2015 07:29 PM
JDMEMone
Apr 7, 2010 07:25 PM
iNERtIA
Apr 3, 2006 09:42 PM
crvtt96
Jun 26, 2004 06:29 PM
