Map sensor problem
Old Jun 8, 2006 | 02:08 PM
ALL MOTOR DA's Avatar
Default Map sensor problem
Are map sensors interchangable mine is on the firewall and if so which ones can i use
Old Jun 8, 2006 | 05:58 PM
unknown0001's Avatar
Default Re: Map sensor problem (NA EG6)
you can use any map sensor that is the correct OBD I belive, so you can use a throttle body map sensor like a firewall sensor and vice-versa
woojdm
Jun 9, 2009 08:54 PM
reddysol
Sep 8, 2007 10:57 AM
dseriesdrag
Sep 21, 2006 09:32 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
