oil pan drain bolt stripped..?
Old Jun 11, 2006 | 07:02 PM
EikoU's Avatar
Default oil pan drain bolt stripped..?
My oil pan drain bolt is stripped. You tighten it to a certain point and if you tighten it a bit more, it just gets loose. Is there any way to fix this? Or do I have to get another oil pan?
Old Jun 11, 2006 | 07:57 PM
eg6T's Avatar
Default Re: oil pan drain bolt stripped..? (EikoU)
you can re tap the threads
Old Jun 11, 2006 | 10:44 PM
Takumi Fujiwara's Avatar
Default Re: oil pan drain bolt stripped..? (eg6T)
I believe they sell slightly larger drain bolts for this exact reason... still have to tap it if you want it done properly.
Old Jun 12, 2006 | 02:53 AM
EikoU's Avatar
Default Re: oil pan drain bolt stripped..? (Takumi Fujiwara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara &raquo;</TD></TR><TR><TD CLASS="quote">I believe they sell slightly larger drain bolts for this exact reason... still have to tap it if you want it done properly.</TD></TR></TABLE>
Do you know where I could buy one? autozone? Or at least the name of them so I could search around.
Old Jun 12, 2006 | 09:34 AM
eg6T's Avatar
that would be a pretty large tap.id say search on the net for one.i dont know what store would carry one that large
Old Jun 12, 2006 | 04:37 PM
CRXified's Avatar
are u using a crush washer when u are trying to tighten it? use a new 1 every time also, buy from honda for a few cents
Old Jun 12, 2006 | 08:14 PM
EikoU's Avatar
Default Re: (CRXified)
I found a oil pan drain bolt that makes a new thread but it has another 10mm bolt inside of the drain bolt which is what i loosen now to drain my oil while the larger bolt stays locked so oil doesn't leak. I found it at a local auto parts store, works fine and was only $15 bucks. Saved me from having to buy another oil pan and oil return fitting.
thanks for the info guys!
liquidx
Aug 8, 2010 03:58 PM
Spithead051
Dec 17, 2008 03:53 PM
93(Civic)EG6
Nov 3, 2006 02:25 PM
MechEng
Oct 21, 2005 12:14 PM
megaman096
17
Dec 5, 2004 03:09 PM
