turning FPR's down..
Old Jun 10, 2002 | 07:54 PM
LSyellowREX
Guest
Posts: n/a
Default turning FPR's down..
i was wondering, if i dont pass my smog test tomorrow, i know it would be because of my fuel flow-- my B18a runs really rich.... so if i bought an aftermarket FPR, would i be able to turn the fuel pressure down below the stock FPR pressure? if so, would any aftermarket FPR be adjustable like this? and if the FPR isnt why my engine is running so rich, then how else could i turn the fuel flow into the cylinders down?? thanks
Old Jun 10, 2002 | 09:01 PM
erniecars's Avatar
Default Re: turning FPR's down.. (LSyellowREX)
replace your map sensor
Old Jun 10, 2002 | 09:47 PM
LSyellowREX
Guest
Posts: n/a
Default Re: turning FPR's down.. (erniecars)
replace it? to what? oh, and thanks for all your help in the past, ernie
Old Jun 10, 2002 | 09:49 PM
dirtySOHC's's Avatar
yes it can be turned down below stock pressures......just make sure you get a fuel gauge as well...
Old Jun 10, 2002 | 10:06 PM
LSyellowREX
Guest
Posts: n/a
Default Re: turning FPR's down.. (dirtySOHC's)
would i be able to turn any aftermarket FPR below stock fuel pressure? cuz i was looking at some of them, and all i see is the pressure guage sticking out the side of em...
Old Jun 10, 2002 | 10:11 PM
Halo's Avatar
actually I knew someone who failed the "visual" part of the test because of his b&m fpr, i painted mine black to conceal it a little better.
Old Jun 10, 2002 | 10:23 PM
LSyellowREX
Guest
Posts: n/a
Default Re: turning FPR's down.. (Halo)
can you adjust the fuel pressure below stock levels with a B&M?? pweeeez, someone help..
Old Jun 10, 2002 | 10:27 PM
yes you can turn it below stock pressures......i was just saying to get a fuel gauge so that you know where you are putting the fuel pressure at........you cant just buy a FRP and mess around with the pressure w/out being able to see wat changes you are making.
Old Jun 10, 2002 | 10:28 PM
yes you can turn it down with a B&M
Old Jun 10, 2002 | 10:34 PM
LSyellowREX
Guest
Posts: n/a
what about the weaponR FPR's.... they already have the pressure guage on the side of them, but would the weaponR's be adjustable too? heres a picture of them....
http://www.nopionline.com/index.cfm?...re%20Regulator
Old Jun 10, 2002 | 10:54 PM
erniecars's Avatar
i wouldnt lean it too much for too long tho or you could burn up a valve. as for the map sensor ive seen some problems with cars running rich because of that sensor giving a false reading. also O2 sensors could be at fault.
Old Jun 11, 2002 | 10:39 AM
LSyellowREX
Guest
Posts: n/a
bump...
Old Jun 11, 2002 | 02:41 PM
yes yes yes yes
Old Jun 11, 2002 | 06:07 PM
GruvyTune's Avatar
New User
if you have a walbro intank pump the B&M wont let you go below 45psi.
dragon1023
Nov 10, 2017 10:36 PM
EFjoe91
Engine Management and Tuning
Jan 7, 2011 10:54 AM
( o )( o )
14
Sep 17, 2006 08:39 AM
mengy007
Sep 2, 2004 11:38 AM
ismkv8s
Jan 21, 2003 02:27 PM
