Skunk2 front upper A arm replacement
Old Jun 11, 2002 | 12:35 PM
Snake's Avatar
Default Skunk2 front upper A arm replacement
Can anyone offer some tips/suggestions on installing the Skunk2 front upper A arm on a 2K Si?
Helms shows the proceedure to remove the arm but there's no mentinon on how to re-install it. My main concern is how to get the ball joint back into the knuckle.
Thanks...
Old Jun 11, 2002 | 01:35 PM
reefer_bob's Avatar
Default Re: Skunk2 front upper A arm replacement (Snake)
When youre putting the ball joint back through the knuckle, you should have enough threads to start it. Lube up the ball joint, and then just tighten the nut down and it'll draw the ball joint through the knuckle...
Old Jun 11, 2002 | 01:53 PM
Snake's Avatar
Default Re: Skunk2 front upper A arm replacement (reefer_bob)
Any suggestions on what type of grease to use? Would normal wheel bearing grease work?
Old Jun 11, 2002 | 02:14 PM
reefer_bob's Avatar
That's typically what I use... just a real light coating is all you need...
Old Jun 11, 2002 | 03:21 PM
EagleR's Avatar
THose A- arms gain some caster or camber?
Old Jun 11, 2002 | 09:13 PM
Snake's Avatar
Default Re: Skunk2 front upper A arm replacement (EagleR)
Camber is adjustable +/- 4 degrees. I hear you can get + 5 deg. of caster by using the right arm on the left side and vice-versa.
Ej8_KiD
Aug 23, 2009 02:27 AM
russianswty
Feb 18, 2007 02:24 PM
Interlinker
Suspension & Brakes
Dec 8, 2006 01:34 PM
Black Ex Coupe
Oct 4, 2004 08:56 PM
EE_Chris
43
Sep 17, 2002 05:10 PM
