Sometimes RPMs stick when i come to a stop. Idle problem.
Old Jun 6, 2002 | 08:11 PM
JM Performance's Avatar
Default Sometimes RPMs stick when i come to a stop. Idle problem.
Sometimes (rarely, but still happens) when I come to a stop at a light, my RPMs do not drop. Instead they stay hovering at 2000-2500. Then sometimes they'll drop down to the normal 800 after a bit and sometimes they wont. Also, I'm not positive about this, but it seems to happen more when I first start driving, not when the car's cold, but when its freshly warm and I just started out.
I've seen this happen before when I'm low, real low, on coolant. However my coolant levels are fine.
Any ideas?
[Modified by 00SilverLS, 12:11 AM 6/7/2002]
Old Jun 6, 2002 | 08:49 PM
CivicEx95's Avatar
Default Re: Sometimes RPMs stick when i come to a stop. Idle problem. (00SilverLS)
On my car the little rubber boot that goes over the throttle cable was holding it open a little bit.
Old Jun 7, 2002 | 12:02 AM
kinesistech's Avatar
Sometimes iacv's go bad and thats typically the symptom. Check it out. You may need a new one.
JDM_EK4_Coupe
Apr 13, 2007 03:54 PM
blackE_T
Feb 4, 2005 01:59 PM
6MTV6
31
Jun 7, 2004 07:14 AM
stRtypR25
Jan 12, 2003 03:09 PM
ASR
Mar 30, 2002 12:04 PM
