starting up problems?
Old Jun 10, 2002 | 09:21 AM
rocket_R's Avatar
Default starting up problems?
i have a 2001 acura type R. the last week, after been run for awhile it'll stall when i'm tring to start it up again. what could be the problem?
it sounds like it's gona start but after about 10 seconds or so it'll start but when it does it sounds like it not getting enough gas cuz it sounds like it's gona die again and the rmp keeps on going up and down for about 5sec.
i had check all the plugs and the are good but the spark plugs all look black. could the spark plugs bee the problems? could i use colder spark plugs and if i do how will the perfomance be like? i have some lying around thats why i'm asking.
there doesn't seem to be any changes when i'm driving in it, only when i'm tring to started it up after it's been ran.
what could i be wrong and what can i check?
Old Jun 10, 2002 | 11:29 AM
Perfectionist's Avatar
Default Re: starting up problems? (rocket_R)
"".... it sounds like it not getting enough gas cuz it sounds like it's gona die again and the rmp keeps on going up and down for about 5sec.
i had check all the plugs and the are good but the spark plugs all look black. could the spark plugs bee the problems? could i use colder spark plugs and if i do how will the perfomance be like? i have some lying around thats why i'm asking.""
RPM up/down... Normally a sign of a vacuum leak, mis-adjusted TPS, or leaking FIV.
Plugs... If they are black you are running too rich or burning oil. A HOTTER range would keep the plugs cleaner, but fix the problem! Don't try to compensate for it.
2001... Isn't it still covered by warranty?
Old Jun 12, 2002 | 09:16 PM
rocket_R's Avatar
Default Re: starting up problems? (Perfectionist)
thanx, i;m also running the skunk2 ecu which is running rich itself. i think the problem was that it wasn't getting enough gas, cuz after adjusting the fuel reg. up alittle the problem didn't seem to be happening.
Jomz0825
14
Nov 13, 2015 01:34 PM
miguey310
13
Jan 19, 2010 06:09 AM
EGhatchLSV
Jan 31, 2008 02:01 AM
streetsweaper
13
Oct 3, 2005 05:36 PM
DOHCon15s
Dec 3, 2003 06:11 AM
