Valves
Old Jun 8, 2002 | 02:35 AM
Xsi's Avatar
Xsi
Default Valves
Does anyone know the difference between the type R valves and the normal B16a ones? Are the diameters different or just the number of angles?
I heard some people use type R inlet valves and reuse the original inlet ones on the exhaust side, anyone done this?
Old Jun 8, 2002 | 06:23 AM
sgT's Avatar
sgT
Default Re: Valves (Xsi)
Exhaust valves are the same.
ITR Intake valves are deshrouded for more flow and less weight, as well as
having a sharper seat angle.
Be sure if you are changing to ITR valves that you have a valve job done so
that they are able to make a good seal with the head.
Old Jun 8, 2002 | 06:45 AM
Xsi's Avatar
Xsi
Default Re: Valves (sgT)
Thanks a lot man
So the Type R and B16A exhaust valves are exactly the same? If someone was going to use B16 inlet valves as exhaust valves, there would have to be quite a bit of work done to it then?
Old Jun 8, 2002 | 12:38 PM
evo's Avatar
evo
New User
The R valve seat are 45 degrees, B16 are 60'
wesley_925
Oct 12, 2021 06:46 AM
YoungMoneySi
Dec 11, 2005 04:21 PM
Burglar
Dec 1, 2002 07:28 PM
Lyonel
Apr 22, 2002 04:01 PM
