what 1/4 times could i expect with this setup?
Old Jun 8, 2002 | 08:13 PM
LSVTEC408's Avatar
Default what 1/4 times could i expect with this setup?
IM running an LS/Vtec
MODS:
B18 block
shottpeened rods
itr pistons
arp head bolts
gsr oil pump
B16 Head
Port and polish
5 angle valve job
itr valve train
crower retainers
skunk2 cams
skunk2 cam gears
itr manifold
itr header
B16(civicSi2k) tranny
itr flywheel
act clutch
skunk2 p28 ecu
i want to get into the high 13's do u guys think its capable with this setup, ill be running in slicks.
Old Jun 9, 2002 | 12:08 AM
rainmanEK's Avatar
big strong guy
Default Re: what 1/4 times could i expect with this setup? (LSVTEC408)
well knowing what kinda car you have would help? and if you plan on drag racing i would stick with r cams, b16 intake manifold, and mill head around ~.0030! though good setup, and even in heavy *** teg i would imagine if built right you could easily be well in 13s! good luck, eric
Old Jun 9, 2002 | 10:48 AM
B-series Assassin's Avatar
Yea, what car is that in? I could imagine some very good times with that setup.
Old Jun 9, 2002 | 10:31 PM
LSVTEC408's Avatar
i have a 94 intera rs, i also got R cams, but they give the same poer as skunk2's so i might as weel stick with the skunk2's, but imm hoping in getting low13, thats my goal. i also got complete MSD ignition w/ 2 step, and bolt ons.
Old Jun 10, 2002 | 06:52 PM
salt's Avatar
If you weigh less that 180, and take out the spare/jack/AC/stereo/PS I think you can be in the high 13's
http://www.geocities.com/realstreetpower/
check that out
13.9 would be about 206hp
Na-Spirit
29
Sep 8, 2010 11:40 AM
importboi22
Mar 24, 2004 02:31 PM
lke2drvgsr
Oct 15, 2003 04:17 PM
Mi-4Teg2
Mar 10, 2003 04:54 AM
VtecDA9
Nov 29, 2002 07:18 PM
