Tranny problems
Old Jun 7, 2002 | 05:14 PM
DOHCarp's Avatar
Default Tranny problems
Alright here is the situation......I just got mycar back from the salvage yard and I tried to shift it into gear and it is extremely hard to get it into gear.
I then took out the role pin from the shift linkage to try and find out if it is just my shift linkage thatis bent from the forklift moving it around. I then tried to shift it with just putting a screwdriver in the hole and it went into every gear but I had to force it in it seemed. is thisn normal orshould it just glide in if their is no linkagte on it.
Also is their a way to fixthis if the shif for is bent.....I meen is their an inexpencive way to fix this without cracking the tranny or bringing it to a tranny shop.
thanks for the help
oh its aB16a2 in a 92 hatch with a cable YS1 tranny.
Old Jun 8, 2002 | 12:19 AM
DOHCarp's Avatar
Default Re: Tranny problems (DOHCarp)
ttt
Old Jun 8, 2002 | 01:16 PM
DOHCarp's Avatar
anybody have an idea?
Old Jun 8, 2002 | 04:49 PM
Rocket's Avatar
Why was it on the forklift?
Your tranny should be okay. It takes a bit of force to shift the tranny with a screw driver. I do this all the time when I am checking trannies I build.
You may need to straighten out your shift linkage if you can. The shift linkage is mild steel so it won't be too hard to bend.
jvo8
Aug 11, 2024 07:12 AM
turboef90
Transmission & Drivetrain
Apr 25, 2018 08:07 AM
dinthanonh
Oct 12, 2009 02:09 PM
mmmbrapND
Apr 7, 2009 06:18 PM
slowcrx954
17
Sep 3, 2007 11:33 PM
