tec 3 or hondata?
Old Jun 11, 2002 | 12:22 PM
ryu12341's Avatar
Default tec 3 or hondata?
have any of you guys had any experience with either of these engine management systems? I have heard good things about the tec 2 and 3 by sport compact car. But I see a lot of people in these forums using hondata. What do you guys think is the better system. Thanks in advance
Old Jun 11, 2002 | 12:44 PM
sgT's Avatar
sgT
Default Re: tec 3 or hondata? (ryu12341)
With the TEC system you have to run a crank trigger.
I have only seen crank trigger wheels that run the Alternator ONLY.
If you wanted to keep AC and PS then it probably wouldnt happen.
Old Jun 11, 2002 | 12:49 PM
TurboSedan's Avatar
New User
Default Re: tec 3 or hondata? (sgT)
Yeah, so if you want to keep those creature comforts then go Hondata!
Old Jun 11, 2002 | 03:05 PM
saso
Guest
Posts: n/a
not true
Old Jun 12, 2002 | 10:58 AM
Shu's Avatar
Shu
I can't find it now, but I recently saw an electromotive dealer on the web who had a honda trigger wheel setup that mounted where the distributer is and reads from the cam. probably not as accurate as from the crank, but at least as good as the stock distributer and a hell of a lot easier than custom fabbing a trigger wheel to the crank.
If someone has links to dealers with honda trigger wheel mounting setups please post them.
mxer518
Apr 18, 2005 05:19 PM
Adi Radoncic
Nov 9, 2003 12:44 PM
impulse333
Sep 25, 2003 09:46 AM
Full-Race Henry
May 14, 2003 03:10 PM
legendboy
Apr 5, 2003 01:50 AM
