iacv check engine light. could a...
Old Jun 10, 2002 | 08:08 PM
thinkbrianthink bu's Avatar
Default iacv check engine light. could a...
im throwing a code for iacv failure after a few minutes of regular driving. recently i swapped to an ex intake manifold. when i did this i bypassed the coolant line to the throttle body. could this be causing the check engine light?
thanks,
brian
Old Jun 12, 2002 | 09:14 AM
Default Re: iacv check engine light. could a... (thinkbrianthink)
t t t
Old Jun 12, 2002 | 03:42 PM
Katman's Avatar
thanks,
brian
nah, the coolant bypassing you did should not be causing your ecu to throw a check light for the IACV. Did you make sure you plugged in the right plug into the IACV sensor? there's another plug of the same style that could get mixed up....check on that.
Old Jun 13, 2002 | 11:09 AM
Default Re: iacv check engine light. could a... (Katman)
im sure its the right plug. its different than the plug on the ex. 3 wire as opposed to the 2 wire on the ex. the thing is, i can clear the code and it will stay off for until the car is warmed up and then it cuts back on.
jdmsir4dr
Apr 4, 2010 12:04 AM
JDMJUNKIEMONKIE
Oct 22, 2009 09:24 PM
VtecCivic93
Sep 2, 2009 10:06 PM
EGTHU6
13
Nov 16, 2006 08:14 AM
Atreyu57
May 16, 2006 12:19 PM
