Converting 91 CRX into Mini Me
Old Jun 8, 2002 | 09:01 PM
UneeK's Avatar
Default Converting 91 CRX into Mini Me
Here's the deal. I have a 91 CRX 1.5 DX. I've recently purchased a 96 Civic Vtech Sohc head, a 99 Vtech computer w/o the harness. Here's my question, what Intakes are compatable with this set up ???? Also what wiring harness will work on the 99 Vtech Computer ?
91 CRX DX 5-speed , Cold air intake, Header, Full exhaust and Jacob's wires.
Old Jun 8, 2002 | 10:47 PM
Redline130's Avatar
Default Re: Converting 91 CRX into Mini Me (UneeK)
To simplify things, you should get a 88-91 Si distributor as it will bolt on to the D16Y8 head. Then you could use a 88-91 Si ecu with some sort of VTEC activation unit, or a P28 (92-95 sohc vtec) ecu using a obd0 to obd1 wiring harness. You should be able to use your CRX intake.
Old Jun 8, 2002 | 11:41 PM
Renegade's Avatar
Default Re: Converting 91 CRX into Mini Me (cyber13)
What kinds of gains can you get out of that setup, say on an 88 CRX Si?
Old Jun 9, 2002 | 12:10 AM
Redline130's Avatar
Default Re: Converting 91 CRX into Mini Me (98401R)
I'd say horsepower output would be about the same as a sohc vtec motor. Somewhere in the 125-130hp range. Maybe a little more using the Y8 head due to the raising of the c/r.
[Modified by cyber13, 1:11 AM 6/9/2002]
Old Jun 9, 2002 | 12:35 AM
Renegade's Avatar
about the same as doing a ZC swap.
Any advantages, besides being cheaper?
Maybe more Torque and well like you said higher c/r.
What is the c/r for a ZC?
buckweeb101
Feb 6, 2013 12:34 PM
MotoCARR
Jun 15, 2003 10:19 PM
743 Stunna
Apr 24, 2003 09:29 AM
BeEfiEBuNz
18
Oct 1, 2002 02:55 PM
