Pinning the block.. can anyone breifly explain the process??
Old Jun 8, 2002 | 01:15 PM
LS-G's Avatar
Default Pinning the block.. can anyone breifly explain the process??
i would imagine the water jacket needs to be machined, then pins inserted. Is it necessary to bore/hone the block after installing the pins? do they need to be welded in?
If someone could explain this procedure in detail or post a link to a site that explains it, i would greatly appreciate it.
thanks guys.
i want to learn more about this, and possibly get it done on my block.
[Modified by LS-G, 10:17 PM 6/8/2002]
Old Jun 8, 2002 | 04:08 PM
LS-G's Avatar
Default Re: Pinning the block.. can anyone breifly explain the process?? (LS-G)
Old Jun 8, 2002 | 04:42 PM
Rocket's Avatar
It's a process of strutting the cylinders to the outside water jacket.
Honing would definitely be a good idea after pinning.
I haven't seen a pinned block yet but this is something we can definitely do once the precisely (CNC) machined pins/struts are made.
Old Jun 8, 2002 | 04:55 PM
BROOD's Avatar
Default Re: Pinning the block.. can anyone breifly explain the process?? (Rocket)
I know of "posting" the cylinder bores to the outer block casing. You use threaded rod made of a material with a similar thermal expansion rate to the engine block material. In the correct locations, a hole is drilled through the engine block and threaded for the rods. The rods are screwed up to the cylinder bores and a very small amount of preload is put on them. The threaded holes in the block are sealed up with a good epoxy (JB Weld or such)
The threaded posts support the cylinder bores almost like a blockguard. But instead the posts are located acording to the location of the highest thrust load that the pistons place on the cylinder bores. This without the cooling problems of a blockguard.
I'm not postitive on all of the techicals but I IMed you with contact info of someone that will. Good luck.
[Modified by SLPR, 5:57 PM 6/8/2002]
TomTread
Apr 21, 2008 01:35 PM
sinister357
May 19, 2005 03:35 PM
HondaGuy02
Apr 20, 2004 08:43 PM
pbomers
Jun 30, 2002 06:41 AM
