timing belt changed, now its knocking
Old Aug 7, 2012 | 11:18 AM
along2285's Avatar
Default timing belt changed, now its knocking
As titled I changed the timing belt and installed a new water pump in a 96 accord non vtec . and upon its first drive I noticed it seemed to rev faster and didn't have the same feel of power. And at an idle there's a knock or ticking that sounds like its the valves. I marked all the pullys and gears as to re align everything as if it hadn't moved. could I be a tooth or two off on the can pully? could really use the help fellas. thanks Andy
Old Aug 7, 2012 | 11:43 AM
slowcivic2k's Avatar
Default Re: timing belt changed, now its knocking
Pull it off and retime the belt, if it ran fine before, your timing is off. Hope that nothing touched.
WrenchinRosie
Jan 24, 2015 08:05 AM
Thagoldenb
Jan 8, 2011 08:20 AM
kaoss_11
Aug 9, 2005 01:55 PM
jjaeschke2
Apr 7, 2003 11:05 AM
