94 civic ex sudden death
Old Aug 18, 2012 | 05:55 PM
Angry_Raisin's Avatar
Default 94 civic ex sudden death
i am having a prople going past 5500rpm... also has low idel and after long tips (25 mile or longer) when coming to a complete stop car dies.. would this have anything to do with having a bad VSS?
Old Aug 19, 2012 | 06:52 AM
Default Re: 94 civic ex sudden death
So no one knows anything. Not even a point in the right direction?
Old Aug 19, 2012 | 07:04 AM
Basik_One's Avatar
Is the CEL on, if so check for codes
Old Aug 19, 2012 | 07:12 AM
Icon3 Re: 94 civic ex sudden death
The only codes it shows is 17 witch I believe is the VSS
Old Aug 19, 2012 | 07:48 AM
Basik_One's Avatar
I'm assuming its not engaging vtec(5500 rpm) which would more than likely be caused by your VSS issue
Old Aug 19, 2012 | 11:47 AM
Do I change the top part? The sensor its self. Or the hole thing with the gear?
Old Aug 20, 2012 | 06:31 PM
Has anyone ever had this problem before?
Old Aug 20, 2012 | 07:13 PM
turbohatch96y7's Avatar
If the vss isn't working then your vtec will not engage.
This could also be your problem with the car shutting off.
Before just changing the sensor verify that you have the correct voltage going into the sensor. And that your ground is okay. Meaning continuity to your chasis. If those two readings check out then monitor your output voltage to the ecu.
Old Sep 2, 2012 | 03:46 PM
ok i changed out the vss, engine light dose'nt turn on now and the car dose'nt shut off anymore but the car still bangs out at 5500 rpm like its got a rev limiter... now the only light thats on is the srs light.... is having that light now cause the v-tec to not work?
Old Sep 2, 2012 | 04:08 PM
No that has no affect
Did you reset your ecu?
Remove the power cable from your battery for 15 min to reset it.
Old Sep 2, 2012 | 04:41 PM
ok i disconnected the neg. battery cable for a good 15 min. or so. i went out for a pass and nope. the car is still rev limiting at 5500
Old Sep 2, 2012 | 06:37 PM
or is it ingauging and im just not noticeing?
Old Sep 2, 2012 | 06:43 PM
Problem might exist in the ecu itself then.
Check over all your grounds, all the wiring, check all the pins on the ecu side. Take the connectors off the ecu and check all the pins make sure none look coroded, pushed out of the connector
Check all the connectors and make sure the pins look ok. Not corroded etc.
Hook up a code reader on the car and go over all the sensor data if its all on point and no sensors are off then swap ecu's.
Or just swap the ecu and keep going from there, if this were my car I would do the first step up top.
Old Sep 2, 2012 | 06:46 PM
What ecu do you have? Check for continuity from the vtec solenoid wires and the vtec pressure switch, back to your ecu.
Old Sep 2, 2012 | 06:47 PM
damn and the ecu was replaced from the previous owner... ok thanks for the heads up i'll start check things out another day when there is day light
Old Sep 5, 2012 | 04:14 PM
ok i have checked out the ECU and i think i found the problem. on the ECU some one wrote on it like if it came out of a junk yard. AUTOMATIC now the numbers on it is 37820-p06-A02 and under that 740-64 AUI is this really the wrong ECU
ps... my civic is manual
Old Sep 5, 2012 | 04:20 PM
P06 is an auto if I'm not mistaken
Old Sep 5, 2012 | 04:22 PM
ok so witch ECU do i need to have? im sure this is why my v tec dont work
Old Sep 5, 2012 | 04:24 PM
p28 with chrome installed, or wichever freeware.
You can send me that p06 and ill chip it for you.
Old Sep 5, 2012 | 04:34 PM
how much? and r u in the houston area?
Old Sep 5, 2012 | 04:36 PM
i have a digital msd window switch after the p06 is chipped would i be able to adjust the v tec with the window switch?
dicecivic94
11
Apr 5, 2013 08:52 PM
bignelson001
16
Jul 13, 2011 03:55 AM
gnuber
Jun 25, 2011 06:26 PM
kevodean
Feb 22, 2009 06:51 PM
Caveman74
Mar 2, 2003 06:29 PM
