d16y7 to d15b swap need help
Old Sep 10, 2012 | 08:02 AM
4doorekboosted's Avatar
Icon6 d16y7 to d15b swap need help
ok i have a 97 ex ek that i recently took the d16y7 out of it and bought a d15b head and block out of a auto 95 coupe. ok this was my first swap doing by myself. i took the dizzy,altnator,intake off the y7 and put it on the d15b now everything mounts up but the dizzy can only mount using 1 bolt frm the way it came off the y7. i broke the plug rit by the oil filter (i think is the oil pressure sensor) but i was told that didnt matter. now i no the d16y7 is odb2 and the d15b is obd1 but im using my stock y7 harness because im not trying to wire vtec up rit now i just want it to start. now its getting spark fuel pump turns on but when i try to start it it sounds like it wants to turn over but dosent like its not gettin enough fuel or i dont know if the firing order is suppose to be for the d16y7 or d15b i just need to no if any1 has done what im doin and if it workd. ive bin doin this swap for a week now and was suppose to have this done in 2days. i have no idea on what is wrong with it and why its not starting all my grounds are hookd up all my connections are connected but i just dont no if i have to use the d15b dizzy or intake or im good. any advice would help cuz rit now im stuck.
for people whos lost on what im doing...
d16y7- tranny,altnator,dizzy,intake,injectors
on a d15b head and block
1.car isnt starting, almost turns over.
2. fuel pumps turns on
3.getting spark
4.need help pm if you think u can help or jus dnt get what im tryna say
Old Sep 10, 2012 | 08:17 AM
Default Re: d16y7 to d15b swap need help
buump
Old Sep 10, 2012 | 08:47 AM
bump
Old Sep 10, 2012 | 10:31 AM
97hb's Avatar
Originally Posted by 4doorekboosted
bump
Make sure distributor timing is synced, and the map and tps plugs are not switched.
Old Sep 10, 2012 | 11:17 AM
HondaPartsHero's Avatar
Technical Hero
Which cam gear did you use?
Old Sep 10, 2012 | 11:44 AM
i dont no which cam gear is used what is that? and i put the dizzy on just like it was on the old motor so timing should be right. i dont no how to check the timing and what map and tps sensor are you talking about. when i plugged everything back in it basically was easy bcuz everything went where it was suppose to go like i said its my first swap im doing by myself. and thank yall for tryna help. i dont no if its the ecu which is a p08 i think whatever comes with the stock d16y7 or i need the d15b dizzy i dont no.
Old Sep 10, 2012 | 02:42 PM
Technical Hero
This is a cam gear, did you use the B7 one or the Y7 because I'm pretty sure you are supposed to use the Y7 to offset the timing
Old Sep 11, 2012 | 08:45 PM
No the d15 cam gear is on it. The y7 cam gear is still on it.. Does that really matter?
Old Sep 22, 2012 | 05:16 PM
ekkrazy's Avatar
Bump
Old Sep 22, 2012 | 05:20 PM
Technical Hero
Did you try the y7 gear, yes it matters
crxfornow
Mar 19, 2020 10:27 AM
turbotegy10
May 13, 2011 06:53 AM
richiejr416
20
Jul 12, 2009 04:34 PM
DSK 86CRX
Feb 1, 2007 02:01 PM
