B16 cranks but won't start.
Old Aug 13, 2012 | 04:17 PM
Built4Battle's Avatar
Default B16 cranks but won't start.
I just swapped in a sleeved b16.
Long story short my car was sitting for bout 6 months so I drained the gas and put in new gas and car started but it ran like **** due to me putting a throttle body gasket upside down. So I flipped the gasket and try to start it nothing. It cranks it has spark its getting fuel all sensors look like its hooked. Timings dead on.
Please HEEEELLLLPPP
Thanks
Old Aug 13, 2012 | 06:45 PM
turbohatch96y7's Avatar
Default Re: B16 cranks but won't start.
Is you battery fully charged??
What's the voltage under a load? (Cranking)
Are you absolutley sure you have spark??
Disconnect the banjo bolt on your fuel rail or just barley crack it open and with a rag around check for the presence of fuel.
Can you hear the fuel pump prime? Main relay click?
Check for 12v at each injector. (Blk yellow wire)
Last but not least since your timing is dead on check for compression.
Old Aug 13, 2012 | 06:55 PM
amarch67's Avatar
did you check the firing order?
Old Aug 13, 2012 | 08:10 PM
Thank you for the idea of the weak battery. I was trying to jump it but it wasn't getting enough voltage. Runs perfect!!
Thank you turbohatch
Old Aug 13, 2012 | 08:55 PM
No problem that's often the problem after messing with a car and working on it having the doors open and trying to crank the engine over on a low battery. Especially when its been sitting so long.
This is why a multi meter is very imporant, and why I always recomend buying one.
nandito
Nov 9, 2011 08:27 PM
JDM Freakk
Jun 21, 2011 05:36 PM
feava510
Feb 15, 2009 10:59 AM
Vtecme92
11
Jun 17, 2006 04:13 AM
4ghatch
May 22, 2004 10:50 PM
