So a put a fuel pressure guage in...
Old Feb 26, 2005 | 01:38 PM
HatchBox's Avatar
Skoobie no more...
Default So a put a fuel pressure guage in...
And this is what i got....
I just put in a walbro 255, and my car runs rough (obviously)
Anyways I just a got a B&M fpr . Do you think it will allow me to go to stock psi?
And what is stock psi for a b16? 30-35 right?
Old Feb 26, 2005 | 01:47 PM
NJIN BUILDR's Avatar
Default Re: So a put a fuel pressure guage in... (HatchBox)
Make sure you didn't pinch the return hose doing the install.The oem regulator should work fine with the walbro.
Glenn
Old Feb 26, 2005 | 02:51 PM
HatchBox's Avatar
Skoobie no more...
Default Re: So a put a fuel pressure guage in... (NJIN BUILDR)
is there anyway to check this line without dropping the tank?
Old Feb 26, 2005 | 03:05 PM
You might be able to disconect the return line after the regulator.Stick a hose on it and run that hose into a gas can.Start it up and check the pressure.
Glenn
Old Feb 26, 2005 | 10:40 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">Anyways I just a got a B&M fpr . Do you think it will allow me to go to stock psi?
And what is stock psi for a b16? 30-35 right? </TD></TR></TABLE>
The bottom half of the oem regulator will work at 45 psi and below. Above 45 psi the return orifice is too small and you'll run rich especially at idle. Stock fuel pressure for the b16 is 35-41 psi with vacuum hose disconnected from the intake manifold.
Old Feb 27, 2005 | 08:56 AM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">You might be able to disconect the return line after the regulator.Stick a hose on it and run that hose into a gas can.Start it up and check the pressure.
Glenn</TD></TR></TABLE>
Good idea Like he said run a hose off the line comming out of the bottom of the regulator into a gas can on the side of the car andcycle the fuel pump a few times..You dont even need to start it actually.
Old Feb 27, 2005 | 09:25 AM
HatchBox's Avatar
Skoobie no more...
Default Re: So a put a fuel pressure guage in... (Tbone)
what do i look for if i dont have to start the car?
it reads 93-100 when car is on, and goes back down to 35 or so when car is off.
Just replaced fpr and no change
Old Feb 27, 2005 | 11:54 AM
Tbone means you don't need to actually start the car up to check the pressure.Just turn the key to the run position without turning it all the way to engage the starter.Just be careful disconnecting the return hose.If it is pinched on the other end,it may be pressurized with fuel.
Glenn
Old Feb 27, 2005 | 04:10 PM
HatchBox's Avatar
Skoobie no more...
so you mean it will return fuel when it primes.
Old Feb 27, 2005 | 04:27 PM
Tbone's Avatar
Yes when you cycle the key it will build the pressure in the line up till where your regulator is set, anything over that pressure will pass through the regulator and return to the gas tank via the return line. If your return line is pinched or clogged in any way, or you regulator is bad it wont allow the excess pressure in the line go back to the tank and will cause it to back up and show extreme line pressure on the gauge like yours is..
Old Feb 27, 2005 | 04:30 PM
Tbone's Avatar
Btw , did you put together the B & m ? I think you installed the spring wrong and this is why its pegging, it wont let the fuel drain back because the valve is being forced shut because your spring is in wrong
Old Feb 27, 2005 | 04:37 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Btw , did you put together the B & m ? I think you installed the spring wrong and this is why its pegging, it wont let the fuel drain back because the valve is being forced shut because your spring is in wrong</TD></TR></TABLE>
it showed high pressure with the stock fpr. Then i put the b&m in and it still does the same thing.
how can you put the spring in wrong?
Old Feb 27, 2005 | 04:40 PM
HatchBox's Avatar
Skoobie no more...
just put the return line in a bottle primed the system and it put gas through the return line and into the bottle.
&lt; stumped
Old Feb 27, 2005 | 04:42 PM
OKOKOKOKOKOK
Check the return..check the return....check the return.ahhhhhhhh
Glenn
Old Feb 27, 2005 | 04:43 PM
HatchBox's Avatar
Skoobie no more...
did did did
Old Feb 27, 2005 | 04:57 PM
Well thats it for my idea's.Seems odd that the fpr would jam closed at the same time you changed the pump.85#'s are about what the walbro pumps make with the fpr closed.
Glenn
Old Feb 27, 2005 | 04:59 PM
athoughts's Avatar
i have an B&M fpr with the gauge as well but mine runs at like 48 and like 50+ with the hose unpluged..
On my air/fuel gauge when i accelerate in any gear, it stays way red and way lean until about 3k rpm ...
i would say its not correct
ideas?
Old Feb 27, 2005 | 05:48 PM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">just put the return line in a bottle primed the system and it put gas through the return line and into the bottle.
&lt; stumped </TD></TR></TABLE>
Ok but more importantly, while it was draining into the bottle what was the gauge reading? Did it still go up to 80 psi.. Remember were looking to see if the return to the tank is plugged not the 5 in hose from the fpr to the hard line on the firewall..
Old Mar 11, 2005 | 03:59 PM
HatchBox's Avatar
Skoobie no more...
GOD DAMN,
Well i took off the fuel rail, injectors all the fuel lines and cleaned out the fuel rail, and fuel lines.
I even dropped the tank incase a line was pinched.
But now it still runs at 100 PSI!!! But its not really sputtering like its rich. And the smoke out the back isnt too dark.
Is there any ways to verify if its running rich/lean.? could i tap the o2 sensor and see what the reading is?
Old Mar 11, 2005 | 04:40 PM
spooned out's Avatar
did you try sticking the stock one back in to see what kind of pressure get? maybe you got a bad gauge.. when i switched to walbro 255pump and B&M regulator it bump my pressure to 48psi and cannot adjust it lower.... someone has a thread on B&M fpr so that you could get the pressure lower.... drilling a tiny hole in the stock fpr and it solved my problem now its ideling at 38psi...
Old Mar 11, 2005 | 04:57 PM
HatchBox's Avatar
Skoobie no more...
Default Re: So a put a fuel pressure guage in... (spooned out)
guess i gotta find a external fuel pressure guage set
I was gonna try drilling out the fpr but idk how much of a difference it would make i dont know if it would releive the 60 lbs of pressure
97mm_EH3
Apr 12, 2011 05:31 AM
smallttocs
Oct 24, 2008 12:54 PM
allnaturalb16
Jan 13, 2007 01:18 PM
QuickRexSi21
13
Feb 10, 2006 11:57 PM
andrewasf77
Jun 15, 2003 12:04 PM
