EAGLE rod and ARP rod bolt need help!!!!!!!
Old Apr 7, 2007 | 11:55 PM
EG hunter's Avatar
Default EAGLE rod and ARP rod bolt need help!!!!!!!
deleted
Modified by 13s del sol at 9:32 PM 5/29/2007
Old Apr 8, 2007 | 07:11 AM
EG hunter's Avatar
Default Re: EAGLE rod and ARP rod bolt need help!!!!!!! (13s del sol)
some one help????
Old Apr 8, 2007 | 10:39 AM
Mikey3000's Avatar
i wish i could help but i can't understand your explanation. are you gonna use a stretch gauge after you torque them down?
Old Apr 8, 2007 | 11:57 AM
riceburner700's Avatar
Default Re: EAGLE rod and ARP rod bolt need help!!!!!!! (Mikey3000)
i think what he means is that he had a bolt that wasnt long enough, or was only showing a few threads sticking through. So he tightened it down to spec and is wondering if the motor will be fine.
thats gonna be the week link in that motor if she lets go weather it be at idle or above 8000rpms
Old Apr 8, 2007 | 08:08 PM
EG hunter's Avatar
the rod bolts are all same size, only one of them is "kind of" hard to tight all the way down, it went half way from the rod cap to the rod and it feels like already tighten, then i force it in and torque it. my question is, will it be safe to rev to 8-9k rpm??
Old Apr 9, 2007 | 04:54 AM
hondamanwill's Avatar
NO! you are right this will be the weak link.
question did the ARP's come pre-insttled with the rods?
either the rod cap or bearing has been dropped installed wrong or both. that rod and cap with new ARP should be taken back to machine shop and checked. they have a procces to torque the rod cap and check the mating surface and roundness of rod. this will inshure you will have no problems with that rod bearing.
Just take the whole thing down to them and ask there advice.
p3t3rxp4n
33
Feb 4, 2015 08:41 PM
GSR615
Jan 23, 2009 11:13 AM
EG hunter
Apr 10, 2007 10:53 AM
EG hunter
Apr 8, 2007 09:25 AM
b2Ovtec
11
May 11, 2004 12:51 AM
