how to check motor?
Old Apr 7, 2007 | 02:58 PM
pnoyboldstar's Avatar
Default how to check motor?
i know when a motor is in a car, you can perform a compression test to check the health of the motor. my question is how do you check one not running in a vehicle? is there anything particular to look for besides the obvious (ie sensors, rust etc.). i searched, but don't know if i'm wording this correctly. thanks
Old Apr 7, 2007 | 05:48 PM
slo blue's Avatar
Default Re: how to check motor? (Russell_K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russell_K &raquo;</TD></TR><TR><TD CLASS="quote">There's a tool called a borescope which is a fiber optic cable you can stick through the spark plug holes. It gives you a good look at the cylinder walls which is what I'd consider most important.
They cost about $200 though . Maybe you can rent one from somewhere.
Also, I'd at least pop off the valve cover and inspect the valvetrain for excessive wear. Maybe even turn the engine over by hand to make sure there's no binding or bent valves.
Oh, and you can also do a leakdown test. That should probably be #1 thing to check.</TD></TR></TABLE>
this is a good idea
you could also find a transmission and bolt a starter up to do a compression test.
jonyi27
Nov 29, 2012 10:22 AM
drumminforev
27
Oct 9, 2006 12:56 PM
poorman's type-r
Dec 17, 2005 10:30 PM
tianporn
Nov 3, 2005 03:28 PM
B18Cej1
Mar 5, 2004 09:37 AM
