ITR flywheel on b16 woes
Old Apr 3, 2007 | 05:02 PM
civickid03's Avatar
Default ITR flywheel on b16 woes
I understand all B series flywheels are interchangable, the gsr and b16 being 18lbs and the ITR being somewhere around 16lbs. However I know the bolt lengths of the GSR/ITR is different, so for a b16a (first gen) can I safely use the ITR flywheel? If so can I use the stock flywheel bolts. I understand the GSR's are too long I am jsut paranoid.
Old Apr 3, 2007 | 05:55 PM
mmuller's Avatar
Mad Scientist
Default Re: ITR flywheel on b16 woes (civickid03)
flywheel bolts are the same length , maybe you got auto ones?
Old Apr 3, 2007 | 10:46 PM
SlowReaction's Avatar
Default Re: ITR flywheel on b16 woes (mmuller)
There all the same as stated before. The auto bolts are shorter.
92integraVTECgsr
Apr 6, 2006 11:03 AM
Ax3l
26
Jan 26, 2006 08:52 PM
chadmasterc
Oct 12, 2005 04:17 PM
Sassafrass
Jan 29, 2003 04:16 PM
asianridr
Mar 29, 2002 05:59 PM
