Can a Manual ECU start a Automatic car? need help...
Old Apr 3, 2007 | 05:32 PM
DIYMIKE's Avatar
Default Can a Manual ECU start a Automatic car? need help...
well my car won't start and i am trying to narrow down the things that could be causing it.
i have a obd0-obd1 boomslang wiring harness and p28 chipped ecu.
i tired the p28 on a integra and it started up fine.
but then i put the harness and p28 into a DA integra 1991 automatic and it did not start.
so is it the wiring harness or since its a manual it won't start?
Old Apr 3, 2007 | 06:49 PM
DIYMIKE's Avatar
Default Re: Can a Manual ECU start a Automatic car? need help... (DIYMIKE)
i searched and come up with different reviews
Old Apr 3, 2007 | 08:47 PM
DIYMIKE's Avatar
anybody?
Old Apr 4, 2007 | 10:28 AM
Relic1's Avatar
make sure B7 is grounded when in the auto trans car. (clutch switch)
Old Apr 4, 2007 | 12:19 PM
BEST1TUNING.COM's Avatar
Default Re: (Relic1)
Nope. Integras use a seperate TCU to control an Auto tranny. Civics do not. The P28 does not support communication to a TCU. You will need a p75 Auto ecu or you could use a few other integra ECU's with custom components to run the manual ..but bottom line is a p28 isnt gonna do it. I dont deal much with Automatics...but I believe I am correct here.
Old Apr 5, 2007 | 12:58 PM
DIYMIKE's Avatar
Default Re: (BEST1TUNING.COM)
okay thank you.
Old Apr 5, 2007 | 03:59 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEST1TUNING.COM &raquo;</TD></TR><TR><TD CLASS="quote">Nope. Integras use a seperate TCU to control an Auto tranny. Civics do not. The P28 does not support communication to a TCU. You will need a p75 Auto ecu or you could use a few other integra ECU's with custom components to run the manual ..but bottom line is a p28 isnt gonna do it. I dont deal much with Automatics...but I believe I am correct here.</TD></TR></TABLE>
You are partially correct. The P28 ecu will not run the automatic car, but it should still start it. And not all integras use TCU's.
Old Apr 5, 2007 | 04:31 PM
DIYMIKE's Avatar
Default Re: (Blown90hatcH)
thanks!!!!! your the greatest. thats why i just bought another conversion harness from rywire!!??
Old Apr 6, 2007 | 10:03 PM
Default Re: (DIYMIKE)
Thanks for clearin that up for me blown90hatch...i had a feeling i might have been off a little.
Old Apr 7, 2007 | 07:03 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">make sure B7 is grounded when in the auto trans car. (clutch switch)</TD></TR></TABLE>
the reason why I said that is not due to the TCU, the P28's B7 needs to be grounded (showing that the clutch is in or auto trans is in park/neutral) to allow the car to start... it will not even turn over if the pin is not grounded.
Old Apr 7, 2007 | 05:20 PM
DIYMIKE's Avatar
the car cranked and turned over fine. but thats all it did and a CEL came on.
that is all.
OMG WTF
11
May 19, 2016 12:35 PM
turbotime
Nov 29, 2003 03:53 PM
