trouble after replacing master cylinder
Old Mar 3, 2008 | 12:58 PM
Del Sol on Steroids's Avatar
Default trouble after replacing master cylinder
went from 13/16" to 15/16" master cylinder, couldn't change 4040 proportion valve because need to oreder and bend a new line. But the trouble is now after 6 bleedings, the pedal barely touches the floor.
could it be because it needs the 4040 proportioning valve, or was it just a bad master cylinder?
Old Mar 3, 2008 | 01:44 PM
ekb16's Avatar
did u bench bleed the MC b4 u hooked it all back up
Old Mar 3, 2008 | 02:29 PM
Default Re: (ekb16)
yes i did
Old Mar 3, 2008 | 08:14 PM
Default Re: (ekb16)
it has the symptom of a bad master cylinder, it's pretty stiffed when the car is off, but after driving, it floors.
Old Mar 4, 2008 | 03:00 AM
Default Re: (Del Sol on Steroids)
help!
Old Mar 4, 2008 | 06:41 PM
bjr338's Avatar
Bleed all the air from all 4 brakes... Get a friend... start with the farthest brake, have friend pump pedal 4 times and hold it down. You then open the bleeder line and your friend will tell you the pedal is now down. While he holds it down, you close the bleeder valve. Then repeat the process on that same wheel until all air bubbles are gone. Make sure fluid does not run out in the reservoir. Then repeat on the rest of the wheels.
Old Mar 4, 2008 | 08:13 PM
Default Re: (bjr338)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids &raquo;</TD></TR><TR><TD CLASS="quote">went from 13/16" to 15/16" master cylinder, couldn't change 4040 proportion valve because need to oreder and bend a new line. But the trouble is now after 6 bleedings, the pedal barely touches the floor.
could it be because it needs the 4040 proportioning valve, or was it just a bad master cylinder?</TD></TR></TABLE>
the car was bled a total of 6 times.
1.bench
2.m/c installed
3-6. all four brakes
Old Mar 4, 2008 | 11:19 PM
inspyral's Avatar
Is it a used MC? Does it hold pressure when you pump the brake repeatedly, and then slowly sink to the floor with steady pressure? That's what my used 1" MC did after driving around for a while, or on hot days when it'd get heatsoaked. Replaced it with a reman 1" MC, and that fixed it.
Old Mar 5, 2008 | 07:52 PM
Default Re: (inspyral)
new from autozone, replacing that now with new oem. maybe it was just a bad MC. and no, the pedal would just go to the floor, woould hold pressure. it would engage the brakes but at the floor.
it hold super stiff when engine is off, but when you ride it goes straight to the floor.
hawtsoss
Oct 24, 2008 07:21 AM
redman223
Jun 3, 2007 03:58 PM
PreludePhill
Mar 22, 2007 06:22 PM
yz125rider21
20
Mar 4, 2007 12:58 PM
brockscivic
15
Jul 23, 2006 07:34 PM
