Speed Sensor Problem
Old Feb 29, 2008 | 06:50 PM
DC2man's Avatar
Default Speed Sensor Problem
Today I flushed my tranny on my ej8 and I have a type r swap. I filled it by moving the speed sensor but i accidentally unhooked the sensor before i pulled it out of the transmission. I didnt think anything of it and just put it back together. Now i dont have a speedometer and my check engine light is on and i also don't have vtec. Any ideas what my problem could be?
Old Mar 1, 2008 | 05:11 AM
King V's Avatar
Default Re: Speed Sensor Problem (DC2man)
If you whoopsied it, you might have pulled the pins back inside the connector. Inspect the connection and see if there are any pins pushed back or any of the pins on the VSS are bent.
Old Mar 1, 2008 | 02:31 PM
HONDAPARTSMANMIKE's Avatar
MAKE SURE YOU DIDNT PULL ANY OF THE PINS OUT OF THE VSS CONNECTOR AND THAT ITS PLUGGED IN CORRECTLY CHECK FOR CORRISION ON THE PINS. IF SO REINSTALL THEM. AND CLEAR THE CEL ITS MUST LIKE A SPEED SENSOR CODE.
Old Mar 3, 2008 | 07:01 PM
DC2man's Avatar
Found out my problem i lost my vss joint and it cost me 3 bucks at the dealer and now it works fine
madnad
Sep 18, 2018 06:49 AM
98IntegraLSNonVtec
Dec 24, 2005 11:52 AM
951dc5
Feb 13, 2005 10:48 AM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
Mike95lude
Feb 18, 2002 09:50 PM
