h22 piston rings? HELP!!!
Old Mar 6, 2008 | 05:10 PM
Silvertc's Avatar
Default h22 piston rings? HELP!!!
hey guys i need help, OEM honda rings for my h22 type s are $50 PER cylinder. I'm 18 and trying to build this motor on budget, i have found a couple of different rings that are OE FORM ,anyone know if i will be ok using these rings? I know there is an FRM coating on the stock blocks of H22's so im making sure these Wannabe OEM piston rings are ok for my car.
http://www.autopartswarehouse....86881
http://cgi.ebay.com/ebaymotors...ZWDVW
Thanks in advance honda-tech!
Old Mar 7, 2008 | 05:16 AM
Lubo_25's Avatar
Default Re: h22 piston rings? HELP!!! (Silvertc)
sometimes you need to bite the bullet my friend...get the oem rings and be done with it...there is no compromise on an frm block unless you sleeve the block and go fresh...
my .02 cents
Old Mar 7, 2008 | 09:42 AM
Silvertc's Avatar
Default Re: h22 piston rings? HELP!!! (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">sometimes you need to bite the bullet my friend...get the oem rings and be done with it...there is no compromise on an frm block unless you sleeve the block and go fresh...
my .02 cents </TD></TR></TABLE>
ya..thanks appreciate man
Lude@Heart
Oct 23, 2010 01:48 AM
sadam-insane
Jun 9, 2008 07:22 AM
Silvertc
Mar 10, 2008 08:35 AM
Silvertc
Mar 6, 2008 05:54 PM
