Compression check question
Old Mar 6, 2008 | 01:29 AM
djnikko's Avatar
Default Compression check question
Im doing compression check on a h22 engine except the engine is out the car and not wired in. Ive been turninig the engine over using hand tools and am getting really low figures on all cylinders. Before I go assumimng its the piston rings is there anything I might be doing wrong? Is compression lost if the engine is cranked by hand?
Ive had a starter motor arrive for it today so Im assuming I can hook this up whilst the engine is on the pallet, use it to crank the engine & hopefully get better results.
Any pointers would be appreciated
Old Mar 6, 2008 | 04:02 AM
djnikko's Avatar
Default Re: Compression check question (djnikko)
I have also blocked any stray vacuum pipes incase this is causing some kind of pressure leak
Old Mar 9, 2008 | 07:07 PM
djnikko's Avatar
Bump for an answer
Old Mar 9, 2008 | 07:19 PM
NJIN BUILDR's Avatar
You won't get any usable compression test with out a starter.You could do a leakdown test but those are not very reliable on a cold stored engine.
Old Mar 10, 2008 | 05:38 AM
IanB's Avatar
To get good results, you want to do a compression test on a warm engine, and crank it faster than you can by hand. In the meantime, you still want to see consistent results across all cylinders, but don't expect to get high numbers doing it that way.
Old Mar 10, 2008 | 10:30 AM
djnikko's Avatar
Default Re: (IanB)
Brilliant thanks for the replies! i'll bolt up the clutch, gearbox and starter this eve then crank it over
Old Mar 15, 2008 | 12:05 PM
djnikko's Avatar
Default Re: (djnikko)
I got the test done today using the starter motor and the throttle butterfly jammed open. This is for a H22A engine.
The results were:-
Dry Wet
Cyl 1 150 190
Cyl 2 230 250
Cyl 3 230 260
Cyl 4 250 270
Im guessing cylinder number 1 has either a faulty valve or piston ring, can anyone with a bit more experience enlighten me on this using the table of results?
aimbot
Apr 24, 2007 12:16 PM
AnAccordIsForever
Nov 4, 2006 02:20 PM
aalb1
Apr 6, 2005 09:10 PM
itsmebeaner1987
Oct 31, 2004 11:54 AM
Jonathan_ED3
Oct 28, 2004 03:31 PM
