B16a2 rally engine build advise
Old Mar 1, 2008 | 10:23 AM
interprodavid's Avatar
Default B16a2 rally engine build advise
Hi ,
Im new to Honda tuning but having just bought a Civic ek4 to build in to a rally car thought i better start doing some homework .
I am looking to build a 200 bhp b16a2 with a good power band and as much torque as possible and would really appreicate some advise (cams ,headwork ,valve train ,oil system etc)
Also whats availble for the gearbox I would like to run a straight cut dogbox but dont seem to be able to find anything
Old Mar 1, 2008 | 10:27 PM
blinx9900's Avatar
Default Re: B16a2 rally engine build advise (interprodavid)
links to dogboxes at the bottom:
http://www.ek9.org/forum/trans....html
Old Mar 2, 2008 | 07:18 AM
gibsanez's Avatar
If you want as much torque as possible you shouldn't be starting with a B16
Old Mar 2, 2008 | 10:26 AM
Default Re: B16a2 rally engine build advise (gibsanez)
I am limited by the class to 1600cc and whilst I appreicate that its not the most torquey engine out there its still very important that I have a good power band afterall rally engines spend most of their life accelerating (torque +acceleration ,bhp+topspeed
Thanks for the gearbox info I ve run ppg dogboxes in Imprezas didnt realiize they do a Civic box have sent them a email
Dave
Old Mar 2, 2008 | 08:01 PM
sorrule's Avatar
200 bhp is achievable with a b16 but I don't think it'll meet all of your criteria. You'll have mostly top end, pretty narrow, power band. Torque numbers are pretty low also probably around 120 ft/lbs or less. I have no clue about the class your racing in but consider turboing maybe?
Old Mar 22, 2008 | 11:13 AM
rotten's Avatar
You'll have to wring the neck of of the B16A to get that kind of power, and it won't have a ton of torque.
I think I'd go with some high compression pistons, upgrade valvetrain, port/polish, decent cams and a good intake, header, exhaust. Will be able to rev pretty high, which will be great if you can get a very shortly geared, close-ratio box.
He won't be able to turbo, its a 1600 NA class.
92EgDelsol
Jun 24, 2015 02:19 PM
MFactory
Honda Insight & CR-Z Hybrid
29
Feb 11, 2011 11:57 AM
slow_455_civic
49
Aug 27, 2006 01:30 AM
u_tal
Feb 24, 2006 02:29 PM
Soon2b8b
22
Feb 23, 2004 12:53 PM
