Stripped Oil Pan Solutions Needed!
Old Mar 2, 2008 | 12:28 PM
dand39's Avatar
Default Stripped Oil Pan Solutions Needed!
So it looks like my oil pan's thread is stripped. After some research, I'm now considering using an "expanding rubber plug". Problem is, no stores around here sells them. Does anyone know websites that sells this? How reliable is the plug? Any other recommendations? I want to avoid having to tap it, due to the metal shavings involved.
This is for a 1993 Honda Prelude VTEC. Drain plug size is M14 x 1.5. If someone could tell me the brand name, and part number... or a direct link, that'll be great.
Thanks in advance.
Old Mar 2, 2008 | 12:43 PM
dand39's Avatar
Default Re: Stripped Oil Pan Solutions Needed! (dand39)
Will the Dorman #65200 work? 1/2" Dia.; 5/8" Length
http://www.partsamerica.com/Pr...65200
Or should I go with the 5/8" diameter?
Old May 15, 2008 | 11:14 AM
dubzz24's Avatar
I wouldn't trust one. Think of it this way... if for whatever reason that plug falls out and your oil drains, by the time you shut the car down after the oil light comes on you'll probably already have a spun bearing.
Just take the pan off when you tap it if you're worried about shavings, or get a magnetic drain plug.
Old May 16, 2008 | 09:53 AM
Bjorn20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dand39 &raquo;</TD></TR><TR><TD CLASS="quote">So it looks like my oil pan's thread is stripped. After some research, I'm now considering using an "expanding rubber plug". Problem is, no stores around here sells them. Does anyone know websites that sells this? How reliable is the plug? Any other recommendations? I want to avoid having to tap it, due to the metal shavings involved.
Thanks in advance.</TD></TR></TABLE>
Valvoline Instant oil Change shops have them. But They are more of a band-aid until you get the real issue solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubzz24 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't trust one. Think of it this way... if for whatever reason that plug falls out and your oil drains, by the time you shut the car down after the oil light comes on you'll probably already have a spun bearing.
Just take the pan off when you tap it if you're worried about shavings, or get a magnetic drain plug. </TD></TR></TABLE>
Not sure how expensive they are but if all else fails just get a new oil pan. Thats honestly your only 2 options.
Old May 16, 2008 | 10:08 AM
mulisharider11x's Avatar
Default Re: Stripped Oil Pan Solutions Needed! (Bjorn20)
2x
hydengr
Honda Civic (2001 - 2005)
Jun 11, 2013 03:50 PM
tamadrumr88
Dec 24, 2009 04:34 PM
elmalouno
Apr 26, 2009 07:42 AM
mitch3814
Apr 5, 2005 06:37 PM
AB16A2T
14
Apr 4, 2002 11:32 PM
