K24/20 Tech Info
Old Feb 25, 2008 | 05:09 PM
woolydotmatrix's Avatar
Default K24/20 Tech Info
I have 03 crv block , 03 rsx-s head and tranny
Want to know if the 03 si Accessory idler and tensioner assy will bolt up to the K24 water pump housing ?????? looks like the K24 housing need one more hole drilled and tapped
2.
Can I put a set of TSX pistons on these K24 rods ????
3. will a 06 si LSD dop in the 03 RSX-S trans and if so will the speedo ring gear on the open diff press onto the LSD ???????I know the speed sensor changed locations so I am not sure if thering gear will fit on the Diff
Old Feb 26, 2008 | 05:02 AM
Default Re: K24/20 Tech Info (woolydotmatrix)
I might be Barking up the wrong tree here but i was hoping some one out there might have some kind of answer for me.... Any Ideas
trincivic
Transmission & Drivetrain
Aug 6, 2011 04:59 PM
woolydotmatrix
Feb 27, 2008 07:11 PM
n1_egsex
Aug 29, 2007 02:44 AM
highroller54
Apr 8, 2005 06:04 PM
cluelessmale
Dec 1, 2004 09:45 AM
