O-ringed and 84.5mm pistons i need help???
Old Mar 7, 2003 | 09:27 PM
J2turbo21's Avatar
Default O-ringed and 84.5mm pistons i need help???
Ok i got 83.5mm pistons in my gsr motor right now and its o-ringed.Im going to bore it to 84.5mm.So my question is when i bore it over 1mm what do i do with the o-ring.If you look at the pics,when i bore it over the piston might have a little gap between the top of the piston and sleeve when its at TDC.Im i wrong?What should i do?
Old Mar 7, 2003 | 10:35 PM
MikeSarr_GSR's Avatar
Default Re: O-ringed and 84.5mm pistons i need help??? (J2turbo21)
84.5 in a stock sleeve?
Old Mar 7, 2003 | 10:43 PM
J2turbo21's Avatar
Default Re: O-ringed and 84.5mm pistons i need help??? (MikeSarr_GSR)
Nope the motor is re-sleeved already.
Old Mar 7, 2003 | 11:17 PM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
What gasket are you gonna use? Do you know where to get a head gasket for 85mm pistons?
Old Mar 7, 2003 | 11:20 PM
J2turbo21's Avatar
Default Re: O-ringed and 84.5mm pistons i need help??? (VitaminB20)
I think you get stock gaskets made for 84.5mm bores.I think imort builders can get them along with some other companies.
Old Mar 7, 2003 | 11:22 PM
VitaminB20's Avatar
They have OEM 84.5mm for OS pistons? You sure?
Old Mar 7, 2003 | 11:26 PM
J2turbo21's Avatar
They are oem headgaskets that have been bored out to your desired size.Also please dont jack my post hehe
[Modified by J2turbo21, 8:28 AM 3/8/2003]
Old Mar 7, 2003 | 11:27 PM
VitaminB20's Avatar
Hehe, ok goodluck with your question.
Old Mar 9, 2003 | 11:43 PM
J2turbo21's Avatar
bump
Old Mar 10, 2003 | 09:16 AM
joshwhe's Avatar
why are you gonna bore it out??? how deep are the o ring lands? and what kinda comp are you running?
maybe have the lands welded/filled then machined, then reringed after
[Modified by joshwhe, 10:18 AM 3/10/2003]
Old Mar 10, 2003 | 10:42 AM
Kataku2K3's Avatar
Default Re: O-ringed and 84.5mm pistons i need help??? (joshwhe)
Yea I've heard of overboring OE gaskets and for the most part I think I would like that... I use an OE gasket any time I can... To me they just seem like they seal a lot better than aftermarket.. From the look of your motor and being o-ringed I assume that you are gonna be running high boost and for that I would go with a Cometic headgasket... That's the only time I will not run OE.... (o-ring+big bore+high boost) Why do you wanna go up to 84.5?? looks like you've got a pretty good high boost setup As joshwhe said you could probably just go up to 84.50mm and then o-ring it again... Good Luck... Peace
Old Mar 10, 2003 | 02:52 PM
J2turbo21's Avatar
Default Re: O-ringed and 84.5mm pistons i need help??? (Kataku2K3)
IM going to 84.5 cause im going all motor now.IM just wondering if it will cause a problem.
jay-d-em
16
Apr 18, 2013 03:45 PM
SupaFly_Honda
Jun 25, 2009 09:16 AM
anton_
Nov 25, 2008 03:50 AM
rusted_eyes
17
Jul 13, 2004 05:28 PM
Benny Z
Dec 20, 2002 03:35 AM
