ls crank in a b18c block?
Old Mar 10, 2003 | 10:19 AM
delslow94's Avatar
Default ls crank in a b18c block?
has anyone done this...would it acheive the same out put as an lsvtec? i can get a b18c block for pretty good price would i be able to put an ls crank in it to give it that advantage....thanks guys.
Old Mar 10, 2003 | 11:01 AM
MikeSarr_GSR's Avatar
Default Re: ls crank in a b18c block? (delslow94)
I have seen guys on honda-acura.net that have done this (I believe you need to use a shorter rod) however you will have the same benefit of the longer stroke
of the LS crank w/ more CR... while benefitting from the VTEC infrastructure that is already there... IMO it seems to be the best way to go LS VTEC.
Old Mar 10, 2003 | 11:44 AM
Nameless RB26's Avatar
Here, same questions and answers.
https://honda-tech.com/zerothread?id=436361
and
https://honda-tech.com/zerothread?id=431588
Old Mar 11, 2003 | 11:39 AM
GM2000ITR's Avatar
New User
It's not uncommon to put the LS crank in a B18C at all. Just remember, the counter weights will not clear the oil squirters. They will have to be removed, the holes drilled out, re-tapped and plugged with a bolt (or just welded shut). With that said, why not just go w/ a B18A/B (the only diff. would be the additional VTEC oil line anyways...no biggie.)
Old Mar 11, 2003 | 01:38 PM
Default Re: ls crank in a b18c block? (GM2000ITR)
Have you personally seen that they hit the oil squirters or had experience with this?
Old Mar 11, 2003 | 01:59 PM
GM2000ITR's Avatar
New User
Default Re: ls crank in a b18c block? (Nameless)
Yes.
Old Mar 11, 2003 | 09:11 PM
TimoneX's Avatar
New User
I wouldn't do all that for 37cc of displacement. Plus the LS crank isn't as strong, isn't as well balanced, and doesn't oil as well at high RPM. Not to mention the drop in r/s ratio, unless you use raised pin pistons & longer rods(Eagle).
Old Mar 12, 2003 | 02:31 AM
GM2000ITR's Avatar
New User
Default Re: ls crank in a b18c block? (TimoneX)
LS cranks are just as strong(if not stronger due to their increased mass)than B18C cranks. Balancing is performed equally well on both cranks. I don't know about the oiling characteristics though, but I must say....I have not seen any journal differences. Just my $.02
Old Mar 12, 2003 | 01:36 PM
It's funny that you mention that the counterweights will hit the oil squirters... but you don't mention anything about the deck height of the B18c block if you use LS rods and an LS crank.
I don't know what or who to believe, since no one replies with any detailed information about this.
Old Mar 12, 2003 | 01:40 PM
WAFFLES's Avatar
Deck height is the same with both blocks. GM2000ITR is right.
Old Mar 12, 2003 | 01:59 PM
GM2000ITR's Avatar
New User
Default Re: ls crank in a b18c block? (WAFFLES)
Thanks Waffles.
Old Mar 12, 2003 | 02:02 PM
So would an LS rod be shorter than a B18c rod? I don't get this anymore.
Old Mar 12, 2003 | 02:06 PM
BabyDaddy's Avatar
LS rods are shorter and yes you can keep the oil squirters. I've been able to keep them with my 95mm crank eventhough it required some custom work.
Old Mar 12, 2003 | 02:08 PM
Default Re: ls crank in a b18c block? (BabyDaddy)
What kind of custom work?
Old Mar 12, 2003 | 02:10 PM
BabyDaddy's Avatar
machine off one corner of the squirter block, shorten the tubes and bend them a little, and finally neck-down the end so that they are the same diameter at the end as stock.
Old Mar 12, 2003 | 02:27 PM
sgT's Avatar
sgT
I have done this many times and have found no clearance issues thus far.
Old Mar 14, 2003 | 09:43 AM
Default Re: ls crank in a b18c block? (sgT)
Great.. who to believe.
Old Mar 14, 2003 | 09:45 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Old Mar 14, 2003 | 09:46 AM
BabyDaddy's Avatar
Believe both of us. I'm talking about what has to be done to keep the squirters with a 95mm crank.
He's talking about an LS crank. Shouldn't be any clearance issues with that.
Old Mar 14, 2003 | 10:15 AM
ohh. I see. thansk.
igotthaspirit
Nov 18, 2006 02:27 PM
allinone07860
Dec 8, 2005 07:40 AM
euclid
22
May 11, 2004 08:15 PM
Rescued R
Jul 24, 2003 07:24 AM
Nameless RB26
Feb 27, 2003 10:29 PM
