oil pressure gauge? the sender
Old Mar 11, 2003 | 06:16 AM
untitled's Avatar
Default oil pressure gauge? the sender
i have an electric oil pressure gauge from auto meter and i need to know where the oil sender is located so i can tap into the wire. also the sender i for psi not level right?
Old Mar 11, 2003 | 06:49 AM
Spade's Avatar
Default Re: oil pressure gauge? the sender (88crx91integra)
I believe a sender is supposed to come with the guage.
Old Mar 11, 2003 | 07:10 AM
baldylox's Avatar
Spade is right. Didn't you get a sender with your gauge?
Old Mar 11, 2003 | 12:20 PM
untitled's Avatar
Default Re: oil pressure gauge? the sender (baldylox)
yes but isnt there a factory sender i can tap into for it. this is how i did the electric water temp.i just ran 1 wire into 2. also is that factory for oil level of psi. obviously if it for level it will not work, that is why i ask. i think the oil lights are triggered by sudden changes in oil pressure or when the psi drops below a certain level the ecu trips the light, but i am not sure of this.
Old Mar 11, 2003 | 12:37 PM
sgT's Avatar
sgT
there is no factory sender
even if there were, you would get incorrect readings unless it was calibrated for that gauge
Old Mar 11, 2003 | 02:27 PM
Chiovnidca's Avatar
The factory oil sender is only a switch for the dummy light. It won't work for a gauge. Some models do have a control unit hooked up to it, but it still has the same functon. The stock sender is on the back of the block above the filter.
SoFresh1189
May 3, 2010 06:16 AM
graphic
Dec 7, 2004 10:31 AM
a1320honda
10
May 22, 2004 03:56 PM
