valve adjustment, need answer ASAP thanks
Old Mar 10, 2003 | 03:08 PM
4doorH22's Avatar
Default valve adjustment, need answer ASAP thanks
If the specified range is 0.006" to 0.007", should I use my 0.006 or 0.007 feeler gauge to adjust?
Thanks.
Patch's Avatar
Default Re: valve adjustment, need answer ASAP thanks (4doorH22)
Use the smaller one.
http://www.c-speedracing.com/howto/v...alveadjust.php
[Modified by CRX PAT, 7:09 PM 3/10/2003]
Old Mar 10, 2003 | 03:14 PM
BoostingSnail's Avatar
Default Re: valve adjustment, need answer ASAP thanks (CRX PAT)
IMO I would use the bigger gauge if the engine is cold and the smaller if the engine is warm...shouldnt matter either way tho
Old Mar 10, 2003 | 03:19 PM
Patch's Avatar
Default Re: valve adjustment, need answer ASAP thanks (BoostingSnail)
You're supposed to do a valve adjustment when the engine is cold anyways though.
Old Mar 10, 2003 | 04:28 PM
Lord Helmet's Avatar
true
Old Mar 10, 2003 | 04:53 PM
4doorH22's Avatar
Default Re: valve adjustment, need answer ASAP thanks (sleeperciv)
Cool, thanks. Only 3 of 16 needed adjustment but I expect massive WHP gains.
(j/k)
Old Mar 10, 2003 | 05:54 PM
Yeah you're suppose to but when a customer brings in their car at the honda dealership(or any shop for that matter) for a valve adjustment and the engine is still warm the tech isnt gonna just let the car sit til it's cool when the car is scheduled to be repaired right away....which is why there's that .001" difference I believe
Old Mar 11, 2003 | 05:31 AM
JimBlake's Avatar
Cool, thanks. Only 3 of 16 needed adjustment but I expect massive WHP gains. (j/k)
Yeah - now you'll be able to go out & embarrass those nasty Porsches.
Old Mar 11, 2003 | 07:20 AM
deepgreengsr's Avatar
Default Re: valve adjustment, need answer ASAP thanks (JimBlake)
On cars where we need to get them out fast. We typicaly do the vlave adj last. After a few hours of cooling down. Sometimes in the factory manuals they give you a lash for hot engines. The toyotas need to be adjusted hot(typical). But I let the hondas cool down as long as possible. Im a Perf machannic in Seattle.
lsegcoupe
Dec 22, 2006 08:17 PM
redpeppers
Jul 26, 2005 02:33 PM
Anthrax-VX
Apr 21, 2004 11:07 PM
fe519
Mar 22, 2003 08:53 AM
