seatbelt doesn't reel back in?
Old Mar 9, 2003 | 04:46 AM
SteveeeO's Avatar
Default seatbelt doesn't reel back in?
anyone know how to fix this... I have to manually feed the seatbelt into the little thingy so it will roll up the seatbelt so I can close my door and stuff ... it's such a hassel doing this all the time
sorry for not really being clear, I don't know how to explain it
Old Mar 9, 2003 | 04:53 AM
EPrepCivic's Avatar
Default Re: seatbelt doesn't reel back in? (SteveeeO)
I know exactly what you mean. It sux.
I've never know anyone successfully being able to rebuild the mechanism before. Best bet is to get a new or used replacement.
Old Mar 9, 2003 | 05:26 AM
fathergoose's Avatar
Pull the seatbelt out completlt and spay it with a silicon spray, it usually works.
Old Mar 9, 2003 | 07:55 AM
ViZ's Avatar
ViZ
Default Re: seatbelt doesn't reel back in? (fathergoose)
we have the problem in out prelude and our civic .. .its a pain .. i was thinking of buying replacements... but i also heard that honda replaces faulty seatbelts but i dont think that counts
Old Mar 9, 2003 | 08:23 AM
MattG's Avatar
New User
I thought there was a law that the warranty for seatbelts is much longer than 4 years (maybe 10). So the dealer may be requierd to replace the assembly or at least fix it.
Old Mar 9, 2003 | 08:35 AM
seeNATgo's Avatar
Default Re: seatbelt doesn't reel back in? (ViZ)
My car (the civic) got really bad, and it was really sudded too! I never really had a problem until one random day... do you think it would work to swap the parts from the rear seat belts? No one ever rides back there anyways.
Old Mar 9, 2003 | 11:49 AM
Chiovnidca's Avatar
This usually takes care of it.
From Service Bulletin #91-030:
SYMPTOM
The seat belt will not retract all the way, or retracts slowly.
PROBABLE CAUSE
Dirt on the seat belt webbing and guide.
CORRECTIVE ACTION
Clean the seat belts and guides with a mild soap solution or isopropyl alcohol. This procedure applies only to three-point (active and passive) seat belts. Do not use it for motorized seat belt systems.
Old Mar 9, 2003 | 01:05 PM
SteveeeO's Avatar
Default Re: seatbelt doesn't reel back in? (D16Chiovnidca)
thanks a lot, I'll try that
Old Mar 9, 2003 | 02:56 PM
FifthGearOnline's Avatar
and if that doesnt work just go back to honda and get new ones put back in for free
Old Mar 9, 2003 | 05:48 PM
X0's Avatar
X0
Default Re: seatbelt doesn't reel back in? (FifthGearOnline)
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
yup, that should fix you up.
I've never had to use soap/alcohol before though. Usually you can just extend the belt all the way out and blow it off with an air compressor, or canned air if you don't have access to a compressor.
Old Mar 9, 2003 | 06:46 PM
Jared's Avatar
Default Re: seatbelt doesn't reel back in? (BAdMutHA)
BTW, Honda seatbelts are lifetime warranty.
Old Mar 10, 2003 | 10:28 AM
SteveeeO's Avatar
Default Re: seatbelt doesn't reel back in? (Jared)
ok so I can go up to the dealership and have this done? I will try the compressed air first - but if that doesn't work, the dealership will have to do it for me? someone is saying 10 years... my car is 13 years old (90)
Old Mar 10, 2003 | 10:43 AM
JaeOne3345's Avatar
my car is a 93. I had to do this back in around 2001. my driver seat belt would not retract, therefore making it pointless.
i brought it to the dealership. the guy took me in right away. "oh man, thats no joke, well get you in right this second. we act fast on safety issues".
about an hour and half later, new seatbelt, free of charge. and its not like i bought the car there either. it was like a blind walk in.
Old Mar 10, 2003 | 11:58 AM
Default Re: seatbelt doesn't reel back in? (JaeOne3345)
your car could be a 1977 civic, and they will replace the seatbelts free of charge.
Old Mar 10, 2003 | 12:59 PM
7PSI CRX's Avatar
I'd love to know what dealer you went to.
My local dealer said:
"Leave the car overnight, we'll take a look at the mechanism in the morning and if it's at fault, we'll order a new one from CALIFORNIA!"
I said: "There are none here on the East Coast?"
They said: "I doubt that very much, as your car is 11 years old."
I said "Why can't you just verify the problem now, order the retractors, and give me a call when they come in?"
They said: "It don't work that way, you've got to leave the car untill it's repaired, we cannot release it untill it's repaired due to liability."
I also have a friend who works in a different dealership and he can't get me the retractors without HONDA doing the replacement. (Leaving the car for who knows how long)
I've just gotten used to it.
Old Mar 10, 2003 | 01:15 PM
liquid51's Avatar
Default Re: seatbelt doesn't reel back in? (7PSI CRX)
so what about the motorized ones? I've noticed that I have a fuse for the seatbelts. What do you do for those, aside from taking it to the dealership?
Old Mar 11, 2003 | 05:12 AM
XKWISIT1's Avatar
My seatbelt did the same thing. The cause of this is oils from the hands getting on the seatbelt and thempicking up dust and dirt them being left on the seatbelt anchor at the pillar. The fix is easy get some velcro, about 6 inches of it. Now there are two parts to the velcro, you will be using the rough part. Insert the velcro into the anchor at pillar between seatbelt and anchor,rough part facing the plastic part of anchor and pull the velcro back and forth in a sanding motion, this should fix your problem. depending on the amount of build up some alcohal may make the job easier
Old Mar 11, 2003 | 08:57 AM
X0's Avatar
X0
Default Re: seatbelt doesn't reel back in? (XKWISIT1)
Hmmmm...... Velcro you say? I'll have to try that. Thanks
RAMMINRAM
Sep 14, 2009 08:00 AM
khronicboy420
Jul 15, 2009 06:10 PM
Racer_X7
Aug 1, 2004 06:35 AM
MaxSE02
Jun 2, 2003 03:42 AM
