car bogging under heavy throttle
once again, im having more problems with my swap. It's a 95 GSR motor in a crx. When im driving at around 2k rpms and put about half throttle to it, I feel the motor bog a little. When I leave it in neutral and rev it up a little, it will do the same thing. It doesnt do it all the time tho, only sometimes. Whats wrong here???
FYI, running OBD1 electronics, and throwing codes for O2, Vtec solenoid, and Knock sensor. One more thing, when my cam gears are lined up at TDC, the TDC mark on the crank pulley is about 3-4 centimeters off.
... One more thing, when my cam gears are lined up at TDC, the TDC mark on the crank pulley is about 3-4 centimeters off.
found the problem...my TPS plug was loose
but my timing is still a little off, I can't get it perfect...it still runs fine tho
Check the valve timing in reference to the crank mark. I helped a few buddies change a timing belt on an LS and the timing marks on the cam pulleys lined up perfectly but it ran like crap.
TPS... yeah, I was about to say that
Its safer to use the mark on the crank or the timing belt sprocket, so you don't get your cams 45 degrees off & bend your valves.
I was wondering how the engine would even run if the cam timing was off by 3 or 4 cm!
mrmoomoox
May 10, 2010 07:42 AM
dayaftertomorrow
Feb 12, 2005 06:13 PM
