N/A or TURBO?
Old Jun 6, 2004 | 06:53 PM
JdM_Eg_6's Avatar
Default N/A or TURBO?
HEy i was just wondering what you guys here at ht have experienced with n/a d16z6's and turbo charged d16z6's? i have approximently 2,000 to spend and i want the fastest possible set up can you guys help me out here?
Old Jun 6, 2004 | 07:55 PM
JdM_Eg_6's Avatar
Default Re: N/A or TURBO? (JdM_Eg_6)
bump
Old Jun 6, 2004 | 08:05 PM
Cain Marko's Avatar
Rotary Lift Specialist
turbo it, D16's can handle a good amount of boost on stock sleeves, best i heard was 18, so even if you wanted to run higher boost, pretty much your major parts would be rods and pistons, and together thats about 500-600$ if you know where to look
Old Jun 6, 2004 | 09:44 PM
JdM_Eg_6's Avatar
Default Re: N/A or TURBO? (turtlecx92)
thanks for the info keep it coming! what about my sleeves do i need to get them re-sleeved to make them stronger if i want to run high boost? and if so how much does it cost to get a block done? what c/r pistons should i use?
Old Jun 6, 2004 | 09:48 PM
Cain Marko's Avatar
sleeves can be kinda pricey because they require the block to be sent out and machined and **** like that, check out aebs sleeves, theyre good for real high psi, just make sure everything else is built and tuned right to handle that kind of pressure, other than that, 18psi should get you around 300whp, which is good no matter what anyone says
Old Jun 6, 2004 | 10:06 PM
JdM_Eg_6's Avatar
well i also was wondering what about this set up
d16z6 head stage 3 built by exospeed
d16z6 block with p29 pistons oversized .20/ or any other suggestions on some pistons that i could run a 75 shot with?
gsr t/b port matched to the z6 manifold
forced induction cai
and a bisi header later on
75 shot nos
or should i just run my d16z6 with 18psi and would my stock sleeves handle that and if so how long would it last? what kind of mods do i need to do to allow my car to handle 18psi thanks a bunch for the help guys
Old Jun 6, 2004 | 10:10 PM
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM_Eg_6 &raquo;</TD></TR><TR><TD CLASS="quote">well i also was wondering what about this set up
75 shot nos
or should i just run my d16z6 with 18psi and would my stock sleeves handle that and if so how long would it last? what kind of mods do i need to do to allow my car to handle 18psi thanks a bunch for the help guys </TD></TR></TABLE>
i think all that **** would handle a turbo pretty good, im not the master of turbo **** though, this is just what i know/hear, you will need rods and pistons, maybe some valve work, make sure its balanced and blueprinted and tuned and all that other ****, i mean how much hp do you want to have comin out of your car?
Old Jun 7, 2004 | 07:57 AM
JdM_Eg_6's Avatar
i just want enough power to put me in the 12's or low low 13's
ej_jake
Aug 28, 2017 08:46 PM
bboysake
Aug 11, 2006 03:02 PM
blueb18c
Jan 26, 2006 05:56 PM
xpurespeedx
Jun 27, 2002 08:51 PM
