bad noise in a 94 b18c1
Old Jun 6, 2004 | 02:19 PM
JBBNJ609's Avatar
Default bad noise in a 94 b18c1
gsr at about 120K miles . . .
i/e flywheel/clutch/ itr tranny
i was pretty hard on the car before it started, and then drove it softly to the nearest acme parking-lot.
it sounds like i have a piece of metal moving in my block alittle bit at idle ( idles fine at like 750-900) but at higher rpms 2k and higher the noise is just louder and louder . . called AAA and parked it
the day before i checked the oil level and it was fine . . now my oil is gone and black . . . what could it be ??
it started just after i had moved from a stop light and when its got up to higher rpms i could feel it at the gas pedal, clutch and brake pedal, like a vibration, then i could really hear it and feel it at the floor, then i parked it and a friend looked at it, he said he thinks its a bearing and its in the bottom end . . . it sounds horrible
it sounds like metal rattling around as i rev it higher. . . its hard to explain it better
Old Jun 6, 2004 | 02:49 PM
pb16b's Avatar
Default Re: bad noise in a 94 b18c1 (jason bouchard)
is it like a tapping sound? if so, that's probably from oil starvation. the top end (cams and rocker) are dry. find out where your oil's going and do a leakdown check.
Old Jun 6, 2004 | 03:09 PM
JBBNJ609's Avatar
Default Re: bad noise in a 94 b18c1 (pb16b)
yea kinda a tapping, but worse like not valve tap really more like a rock giggling around in the lower block its reall bad and i may even make a video if i decide to start it before i start tearing it down . . .
Old Jun 9, 2004 | 09:47 AM
JBBNJ609's Avatar
ok so me and 743 took my oil pan off and one of the bafflings on my 10-94oil pan was off and the welding came off . . . here are pics
http://www.spatula-city.us/upl...3.JPG
http://www.spatula-city.us/upl...5.JPG
http://www.spatula-city.us/upl...6.JPG
http://www.spatula-city.us/upl...7.JPG
Old Jun 9, 2004 | 11:09 AM
Quitripin's Avatar
check your oil pump see if the oil pump gear is fine. might need to tear it apart.
Old Jun 9, 2004 | 11:20 AM
JBBNJ609's Avatar
Default Re: bad noise in a 94 b18c1 (Quitripin)
damn, yea well its shitty welding from 10-94 that made this happen . . .
how should i clean out the shavings in my engine besides tearing it down ??
i have seafoam to maybe flush out the engine after i put everything back together . .
Kahl23
Honda Civic (2006 - 2015)
May 16, 2012 08:57 AM
redLUDEs2k1
Nov 21, 2005 07:11 PM
Drew96EJ
Jul 25, 2004 03:25 PM
User 5426
Jul 5, 2004 12:00 AM
TeH PLAYA
Mar 21, 2003 09:42 AM
