axle stuck in trani b18c1 HELP!
Old Jun 5, 2004 | 09:29 PM
oMek's Avatar
Default axle stuck in trani b18c1 HELP!
ok it all stated about a month ago i started brakeing pass side cv joints like nothing, yesterday i tryed to swap the axle in and the part that goes in the trani WONT come out, it spins fine but it will not slide out.
i tryed 3 diffrent pry bars and i used all my weight and it still wont come out.
i talked to a buncha people and they all telling me my trani is prob fucked and i should start looking for a new 1.
has this ever happend to anyone else? i dont wana pay a shop 200$ to tell me that i need a new trani. if i need a new trani i might as sell use that 200$ twards the trani.
any help would be great!
Old Jun 5, 2004 | 11:00 PM
Muckman's Avatar
Moderator in Chief
Default Re: axle stuck in trani b18c1 HELP! (oMekoneDC2)
Passenger side is always the hardest. If you have to pry on it super hard with a pry bar then something is wrong. I had trouble getting mine off with just a 10" screwdriver but a 12" pry bar it came free easily. The trick is to rotate the half shalf a little bit at a time and try to pry it off, if it doesnt come out, rotate more and try again.
Old Jun 5, 2004 | 11:07 PM
oMek's Avatar
Default Re: axle stuck in trani b18c1 HELP! (Muckman)
i deff think something is wrong, this thing wont budge, the trani runs fine so i have no idea if its fucked or not. im hopeing i can take it to a shop and they can just pop it out.
Old Jun 5, 2004 | 11:56 PM
murtnabila's Avatar
try this...stick a pry bar or something in between it. Then get a fork (try and find one with the highest pitch possible), so now hopefully the fork just barely fits...but make sure it does fit. Now hammer the fork in. The wedge on the fork should give the axle plenty of what it needs to pop off. Try this little at a time while spinnining the axle. I'm thinking the ring on that axle probably is stuck for some reason. Hey, maybe it'll work and no new tranny! Otherwise...well you tried!
Old Jun 6, 2004 | 01:44 AM
b00sted93Hatch's Avatar
Default Re: axle stuck in trani b18c1 HELP! (murtnabila)
Yea do what they guy above said or you could also find a big flat head and hammer it in between the axles housing and tranny.
Old Jun 6, 2004 | 03:23 AM
crx2fast's Avatar
Default Re: axle stuck in trani b18c1 HELP! (allMotor93Hatch)
i have had a similar problem, but my axle was stuck in my intermediate shaft. dude i seriously tried everything(like went to the local fire station where my buddy worked, and tried the jaws of life on that bitch. didnt budge, just cracked the shaft)
so the problem is that the splines/teeth or set ring of the axle has gottin all fuc#ed up in there, your tranny is still good, but you will never get that piece out
so just unattach it at the boot if you can
Modified by crx2fast at 1:35 PM 6/6/2004
Old Jun 6, 2004 | 11:34 AM
oMek's Avatar
Default Re: axle stuck in trani b18c1 HELP! (crx2fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2fast &raquo;</TD></TR><TR><TD CLASS="quote">i have had a similar problem, but my axle was stuck in my intermediate shaft. dude i seriously tried everything(like went to the local fire station where my buddy worked, and tried the jaws of life on that bitch. didnt budge, just cracked the shaft)
Modified by crx2fast at 1:35 PM 6/6/2004</TD></TR></TABLE>
i did unatach it at the boot, and took the new axle apart tryed to stick them togher only to find out there bearings where diffrent, i switched the old bearings to the new axle and it fit it, but it dont have all the movement it should. i think im gona stick the old axle back togher and put it in, i guess i can deal with clicking for awhile untill i can get it fixed.
Old Jun 6, 2004 | 02:56 PM
oMek's Avatar
ok well today i took the boost apart again and put the old part of the axle back on, now its driveable but i need to get this takein care of asap.
90si-rex
Nov 24, 2008 08:43 PM
crx18c1
Apr 18, 2007 06:13 PM
bigdogc
Jun 11, 2005 12:25 PM
Doogie Howser
Sep 5, 2002 06:44 PM
BoM
May 14, 2002 06:59 PM
