Flywheel bolt and torque question
Old Jun 8, 2004 | 11:13 AM
98EJ's Avatar
Default Flywheel bolt and torque question
I have a 94 gsr motor and I was wondering what size the 12 pt bolts are that hold the flywheel on. Also what is the torque specs for tightening them back up. I have a Haynes manual but I can't seem to find the torque setting for these.
Thanks,
Jeremy
Old Jun 8, 2004 | 12:05 PM
minime's Avatar
Default Re: Flywheel bolt and torque question (98EJ)
should be 17 mm boltsabout 80 to 90 ft lbs
Old Jun 8, 2004 | 01:45 PM
APEX CRX's Avatar
Default Re: Flywheel bolt and torque question (minime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minime &raquo;</TD></TR><TR><TD CLASS="quote">should be 17 mm boltsabout 80 to 90 ft lbs</TD></TR></TABLE>
and tighten in a criss cross pattern
Old Jun 8, 2004 | 02:11 PM
TwoPointZero's Avatar
Banned
Default Re: Flywheel bolt and torque question (APEX CRX)
From my past experiences.. I would install brand new flywheel bolts from dealership and use Thread Lock Red. Because they do stretch and re-loosen.
Old Jun 8, 2004 | 03:57 PM
Rod.'s Avatar
Default Re: Flywheel bolt and torque question (TwoPointZero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoPointZero &raquo;</TD></TR><TR><TD CLASS="quote">From my past experiences.. I would install brand new flywheel bolts from dealership and use Thread Lock Red. Because they do stretch and re-loosen.</TD></TR></TABLE>
that is what i did and what i read in one of my import book
Old Jun 8, 2004 | 07:56 PM
98EJ's Avatar
ok thanks for the info guys, but 80 to 90 foot pounds, thats a bit of a difference should I just go to 90 or what. Also isn't red loctite perminant, wouldn't I be better off just using blue?
Old Jun 11, 2004 | 10:10 AM
Banned
Do 90ft torque lbs. Use RED Thread lock. Its not permenant just stonger then blue.
Old Jun 11, 2004 | 10:29 AM
slowazzhatch's Avatar
75ft lbs on your flywheels bolts according to honda...with threadlocker red
edit: actually the RED theadlocker for high heat applications...
Old Jun 11, 2004 | 10:44 AM
UNDER PRESSURE's Avatar
Default Re: Flywheel bolt and torque question (slowazzhatch)
Hey Matt(slowazzhatch) where's my money? remember the $650.00 you stole from me?
killingtwobirds
Sep 11, 2008 11:13 AM
madswapper
May 1, 2005 05:01 PM
mdj_ge
Dec 7, 2004 12:49 PM
90accorddx
Sep 22, 2004 11:48 AM
Integra_Boi
Aug 5, 2003 03:01 AM
