accord 4cyl vs TSX
Old Jun 7, 2004 | 12:22 PM
shawnd's Avatar
Default accord 4cyl vs TSX
curious about the HP diiferances between the 04 TSX and the 04 Accord 4cyl
I see they have this in common: 16-valve, DOHC, 2.4-liter, i-VTEC 4-cylinder
And I see they have these differances:
TSX: peak HP @ 6800 rpm
Accord: peak HP @ 5500 rpm
TSX: compression 10.5:1
Accord compression 9.7:1
But can you guys tell me what physically/specifically seperates the 2 engines? Is there some differant piece or part? Or is it just software?
thanks
Old Jun 7, 2004 | 06:18 PM
SiR Inspired ED7's Avatar
Default Re: accord 4cyl vs TSX (shawnd)
04 TSX
Engine Type
Aluminum Alloy in-line 4-cylinder
Displacement (liters)
2.4
Horsepower (SAE net)
200-hp @ 6800 rpm
Torque
166 lbs-ft @ 4500 rpm
Valvetrain
16-Valve, DOHC, i-VTECTM
Redline
7100 rpm
Compression Ratio
10.5:1
Fuel System
PGM-FI Multi-Point Injection
Injection System
Electronic Direct
Throttle Control
Drive-by-Wire Throttle System
Emission System
LEV-2
Cooling System Capacity
Manual: 5.4 U.S. quarts (5.3 liters)
Automatic: 7.4 U.S. quarts (7.3 liters)
Crankcase Refill Capacity, including filter
4.2 U.S. quarts (4.0 liters)
TSX Automatic
5-Speed Automatic with Sequential SportShift,(TM) Grade Logic Control and Lockup Torque Converter
TSX Manual
Optional: Close Ratio 6-Speed Manual with Magnesium Transmission Case
Gear Ratios
TSX Automatic TSX Manual
1st
2.652 3.267
2nd
1.517 1.880
3rd
1.082 1.355
4th
0.773 1.028
5th
0.566 0.825
6th
0.659
Reverse
2.000 3.583
Final Drive
4.440 4.760
04 accord
Engine Type
In-Line 4-Cylinder
Engine Block/Cylinder Head
Aluminum-Alloy
Displacement (cc)
2354
Horsepower @ rpm (SAE net)
160 @ 5500
Torque (lb.-ft. @ rpm)
161@4500
Bore and Stroke (mm)
87.0 x 99.0
Compression Ratio
9.7 : 1
Valve Train
16-Valve DOHC i-VTEC®
Multi-Point Fuel Injection
yes
Direct Ignition System with Immobilizer
yes
5-Speed Manual Transmission
5-Speed Automatic Transmission (available)
Well i hope that helped a little....
Old Jun 8, 2004 | 04:56 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawnd &raquo;</TD></TR><TR><TD CLASS="quote">But can you guys tell me what physically/specifically seperates the 2 engines? Is there some differant piece or part? Or is it just software?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawnd &raquo;</TD></TR><TR><TD CLASS="quote">TSX: compression 10.5:1
Accord compression 9.7:1</TD></TR></TABLE>Well, there's one hardware difference right there.
I'd guess the camshafts & the software are also different?
Old Jun 8, 2004 | 05:19 AM
shawnd's Avatar
Default Re: accord 4cyl vs TSX (JimBlake)
How does the compression differance imply differant hardware? (obviously, I'm not a car-guy)
thanks
Old Jun 8, 2004 | 05:37 AM
JimBlake's Avatar
Compression RATIO comes from the volume of the combustion chamber when the piston is at the top of the stroke. To increase the compression ratio, you have to shave material off the head gasket surfaces, or use pistons that project farther into the combustion chamber, or some other physical hardware difference that makes the combustion chamber smaller.
Old Jun 8, 2004 | 09:49 AM
shawnd's Avatar
so do you think the TSX uses differant pistons?
Old Jun 8, 2004 | 10:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawnd &raquo;</TD></TR><TR><TD CLASS="quote">so do you think the TSX uses differant pistons?</TD></TR></TABLE>Beats me! They could also use a different head with smaller chambers. If I really needed to know I guess I'd look up part #s.
I guess I was answering your question on a little more theoretical basis.
ragerized's Avatar
it most definitely uses higher compression pistons
Old Jun 9, 2004 | 07:18 AM
shawnd's Avatar
Default Re: accord 4cyl vs TSX (ragerized)
is that something you can replace?
I probably would never do this, just curious.
Old Jun 9, 2004 | 07:22 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawnd &raquo;</TD></TR><TR><TD CLASS="quote">is that something you can replace?</TD></TR></TABLE>Yes, you simply(!) have to dismantle the engine & put them in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawnd &raquo;</TD></TR><TR><TD CLASS="quote">I probably would never do this, just curious.</TD></TR></TABLE>Good, because you shouldn't just do that until you understand ALL the other things that are different, too. Unless you do the whole package, you really have to worry about what's compatible with the hardware & software from your Accord.
alterdcreations
Nov 11, 2006 12:57 PM
j2s2k
Mar 2, 2005 09:51 PM
abeaujuin
Dec 3, 2004 07:33 AM
shawnd
Jun 8, 2004 05:52 AM
lowrightor
Acura TSX
May 27, 2004 02:29 PM
