ACT Flywheel help??
Old Jun 5, 2004 | 11:40 AM
urgonnalearn2's Avatar
Default ACT Flywheel help??
i need to know the correct way to install a prolite flywheel, because on the oem flywheel there is a dot lines up wit each other and on the act flywheel there isn't, some body help thanks.
Old Jun 7, 2004 | 05:11 AM
Default Re: ACT Flywheel help?? (urgonnalearn2)
Old Jun 7, 2004 | 07:15 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urgonnalearn2 &raquo;</TD></TR><TR><TD CLASS="quote">because on the oem flywheel there is a dot lines up wit each other and on the act flywheel there isn't,</TD></TR></TABLE>
Old Jun 7, 2004 | 08:28 AM
Default Re: ACT Flywheel help?? (mmuller)
Is there a wrong way to put this flywheel on or not?
Old Jun 7, 2004 | 08:47 AM
acy76's Avatar
I just installed an ACT streetlite - I had no issues at all.
Old Jun 7, 2004 | 08:51 AM
ultimatehonda's Avatar
The dot is on the oem fly wheel so incase you take the pressure plate off, when you go to install it back it goes in the same place. With the new fly wheel just install and it torque the bolts down to spec and your good to go
Old Jun 7, 2004 | 10:05 AM
spark plugs.
Guest
Posts: n/a
Default Re: ACT Flywheel help?? (ultimatehonda)
torque to spec.
i noticed that when i installed my act stage 2 clutch and p.p. that the old flywheel and clutch assy. had 6 bolts/holes and the new set up has 8. i only used six and so far it's runnin' fine.
Old Jun 7, 2004 | 10:52 AM
Ok thanks
accord99power
Transmission & Drivetrain
24
Jun 11, 2009 12:01 PM
DC2-ProdUcTiOnS
May 9, 2009 06:57 PM
fled
Jul 5, 2006 12:06 PM
remaxxxk
Mar 1, 2006 09:11 PM
275Performance
Apr 30, 2003 05:03 PM
