DIY on Main Relay Check?
Old Jun 4, 2004 | 03:12 PM
AMG's Avatar
AMG
Default DIY on Main Relay Check?
Anyone know how to check the main relay to see if it is functional? All the problems lead to this being the case, so i am wondering how to check it.
Thanks
Old Jun 4, 2004 | 03:37 PM
Honda Virgin's Avatar
Default Re: DIY on Main Relay Check? (dohcVTEChatch)
when my starter went bad, I found out how you check to see if your main relay was working.
Since there was no power going to the starter, when I turned the ignition key from "on" to "Start" all i could here was the fuel pump going. So when I let the ignition key go back to the "on" position, I would hear a click from the area where the fuses are underneath the steering wheel. That click was from the main relay, it is somewhere near/behind the hood release latch.
If there is no click, then your main relay is faulty.
So I suggest unplugging the power wire to you starter, and then try this method.
perpetualburn
Oct 3, 2020 06:08 AM
peteyparado
Feb 9, 2014 07:38 PM
kamakaze1
Jan 24, 2006 03:47 PM
shreddinryguy
Jun 26, 2005 02:03 PM
DsCivicEx
Feb 5, 2004 09:16 AM
