Ignition timing when coolant temperature is low
Old May 27, 2005 | 06:06 PM
Andre's Avatar
Default Ignition timing when coolant temperature is low
I'm in the progress of writing my own software for the Apexi Power FC (https://honda-tech.com/zerothread?id=1208584) and the Power FC has a correction table "Ignition vs. Water temperature (Cold)".
The manual of the FC Datalogit says the values are ignition retard.
But that doesn't make sense to me. Why do you want to retard the ignition under cold engine conditions? I'd guess it is advance because it is safer to run more advance when the engine is cold and more advance will also help to warm up the engine.
So is it retard or advance?
2x0
Engine Management and Tuning
Jun 16, 2018 08:19 AM
RACEPAK
Aug 4, 2015 09:30 AM
Mase
Nov 16, 2011 04:19 PM
evo
Feb 21, 2002 05:11 PM
