Fuel Pressure Regulator questions...
Old May 27, 2005 | 10:48 PM
Exempt's Avatar
Default Fuel Pressure Regulator questions...
I am swapping a D15B VTEC into my CRX Si... And I noticed that the hose that plugs into the FPR is a tad bigger than the nipple on the FPR... I was just wondering, a few things... Whats the best way to correct this? Use my stock FPR? Change the hose size? Also is this just a vacuum hose, or does the fuel actually travel thru it? Just worried about possible leaking, since its right above my alternator (which will spark if fluid drips on it)...
Thanks!
Old May 28, 2005 | 05:24 AM
jrubenis's Avatar
Default Re: Fuel Pressure Regulator questions... (Exempt)
The hose on top of the FPR is just for vacuum. Its impossible for fuel to get in there. The hose on the bottom is the fuel return line. Make sure that is tightly on the FPR to avoid leaks. I would just change the pipe if it doesnt fit it wont make a difference to the vacuum reading. Or just make an adaptor??
jmanuel
Jun 18, 2014 07:57 PM
Raven2201
Jun 10, 2013 06:20 AM
SINISTR
Jan 29, 2008 07:46 PM
crxpwr1
Dec 10, 2006 08:14 PM
beaterman
Oct 13, 2003 10:33 AM
