trying something different with lsvtec
Old May 28, 2005 | 09:10 AM
bOOsTiNSoHcVtEc's Avatar
Default trying something different with lsvtec
Im building a lsvtec setup and I have a few questions. Im going to use a 1st gen manual b16 head on a stock 98 b18b block. Im going for a different approach. I only want to rev to 7500rpms max just for reliability issues and the powerband I desire. Was wondering what stock cams should I use that would make the most power in between the 4000 and 7500 range? also would lowering my vtec point make more power in those ranges? thanks guys
Old May 28, 2005 | 02:42 PM
Default Re: trying something different with lsvtec (bOOsTiNSoHcVtEc)
Old May 29, 2005 | 08:33 PM
anyone?
Old May 30, 2005 | 07:30 AM
B16'D DA9's Avatar
Im wondering the same thing, I have an LsVtec in my 99 teg, its bone stock bottom end and stock b16a head, i only rev to 7500rpm's also for reliabilty reasons, which cams? like he said?
Old May 30, 2005 | 09:18 AM
Kendall's Avatar
Try GSR cams. You'll need to get it tuned to make the most power anywhere. Just changing the VTEC point could hurt power.
Old May 30, 2005 | 09:27 AM
Default Re: (Kendall)
yeah well i meant lowering it and tuning it to make more power in those rpm ranges than past 7500 that i wouldnt be using. so you recommend gsr cams? anyone else with an opinion? thanks
Old May 30, 2005 | 10:15 AM
Kendall's Avatar
It may be that you'll make more power by raising it, you never know until you get it on the dyno.
Old May 30, 2005 | 12:08 PM
true. anyone else?
Old May 30, 2005 | 06:25 PM
Default Re: (bOOsTiNSoHcVtEc)
Old May 31, 2005 | 03:14 AM
Old May 31, 2005 | 12:09 PM
ekgcool's Avatar
In all reality, the 7500 rpm limit you have set will not produce a good power curve for the VTEC head. Now the B16 and GSR cams are pretty comparable, however you will get a little bit more mid-range power out of the GSR cams. Type R or aftermarket will definitly make the most power, but the 7500 rpm limit will not let you make full use out of the cams. In my opinion, pull the crank out of your motor and have it balanced, get the stock rods stressed relieved and shot peened and ther you go...8500 rpm stock block! To be totally honest I have run a B20 stock block to 8500 and never once did it fail. I sold the block and the guy decided to hit 3rd gear after redlining in 4th, which tore the sleeves apart and threw a rod out of the block in 2 places. But the last few sentences are my personal opinion. And to make my opinion much sweeter, there is not a whole lot of cost going into balancing the crank or to shot peen the rods. I paid $30 for a balcance and $65 for the shot peen ( for all 4 rods). CHEAP INSURANCE
Old May 31, 2005 | 12:43 PM
97L-esVeeTeg's Avatar
Default Re: (tekracer)
Something else to keep in mind, you wont have enough compression nor clearance(depending on cam, mill, etc.) to run anything much bigger than a gsr cam anyway.
Old May 31, 2005 | 03:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekracer &raquo;</TD></TR><TR><TD CLASS="quote">In all reality, the 7500 rpm limit you have set will not produce a good power curve for the VTEC head. Now the B16 and GSR cams are pretty comparable, however you will get a little bit more mid-range power out of the GSR cams. Type R or aftermarket will definitly make the most power, but the 7500 rpm limit will not let you make full use out of the cams. In my opinion, pull the crank out of your motor and have it balanced, get the stock rods stressed relieved and shot peened and ther you go...8500 rpm stock block! To be totally honest I have run a B20 stock block to 8500 and never once did it fail. I sold the block and the guy decided to hit 3rd gear after redlining in 4th, which tore the sleeves apart and threw a rod out of the block in 2 places. But the last few sentences are my personal opinion. And to make my opinion much sweeter, there is not a whole lot of cost going into balancing the crank or to shot peen the rods. I paid $30 for a balcance and $65 for the shot peen ( for all 4 rods). CHEAP INSURANCE </TD></TR></TABLE>
Wouldnt that require me to take out the block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg &raquo;</TD></TR><TR><TD CLASS="quote">Something else to keep in mind, you wont have enough compression nor clearance(depending on cam, mill, etc.) to run anything much bigger than a gsr cam anyway.</TD></TR></TABLE>
So your telling me I wouldnt be able to put crower 403's with upgraded valvetrain on my stock block if I wanted to?
Old May 31, 2005 | 08:09 PM
Default Re: (97L-esVeeTeg)
Old Jun 1, 2005 | 07:15 PM
bump
Old Jun 2, 2005 | 03:25 PM
hello?
Old Jun 6, 2005 | 06:14 PM
can i get those questions answered please?
Old Jun 6, 2005 | 06:47 PM
Blaze45's Avatar
Brrraaaap!
You dont have to take out the block but Im sure that it would make things easier... And yes you can use crower whatever with aftermarket valvetrain, but I can almost garuntee that your going to have to rev higher to make power... I wouldnt suggest running crowers stuff, just because Ive seen some of their cams break.... Contact Rocket about aftermarket cams n valvetrain.... I knew a guy who had a CRVTEC in his civic and reved to 8800 stock bottom end. He only had the motor in there for about 6 months before he threw something else in there but it was a wicked setup that hit a 12.4 jun stage IIIs n hondata and a really good tuner...
Blaze
Modified by Blaze45 at 8:59 PM 6/6/2005
Old Jun 7, 2005 | 03:45 AM
Default Re: (Blaze45)
Where can I take it to the balance and shot peen done? How long do you think it would take for them to do?
Old Jun 7, 2005 | 04:48 PM
up
Old Jun 7, 2005 | 05:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">Where can I take it to the balance and shot peen done? How long do you think it would take for them to do?</TD></TR></TABLE>
machine shop, you can probably pick it up the next day, depending on how busy they are.
Old Jun 7, 2005 | 05:21 PM
cool. lets just say i wanna put pistons and rods in it will they also work on that too? and how much do you think it would be?
Old Jun 8, 2005 | 04:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">cool. lets just say i wanna put pistons and rods in it will they also work on that too? and how much do you think it would be?</TD></TR></TABLE>
Old Jun 8, 2005 | 05:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">cool. lets just say i wanna put pistons and rods in it will they also work on that too? and how much do you think it would be?</TD></TR></TABLE> ^
Old Jun 8, 2005 | 06:01 PM
notstock93's Avatar
Maybe some ITR/CTR cams (awesome midrange) and widen the LSA with some cam gears? Thats my thought on the subject.
