what to do??????keep my LS tranny?????
Old May 23, 2005 | 10:48 PM
EFM_ookie's Avatar
Default what to do??????keep my LS tranny?????
i have a gsr swap im planning to put into my EF.... i dont know if i should keep the hydro ls tranny that i have...buy the hasport kit and go hydro.. and then eventually buy a gsr or itr tranny... or should i sell the ls tranny and go b16... which im havin trouble fiinding a b16 tranny in my area.....will the ls tranny really make my car that much slower??????????????????thanks
Old May 24, 2005 | 04:28 PM
EFM_ookie's Avatar
Default Re: what to do??????keep my LS tranny????? (89_Mangina_SI)
ttt
Old May 24, 2005 | 09:42 PM
MajorPayne's Avatar
the ls tranny has very long gears...you can find all the ratios on here if you search, but yes a b16 tranny will make a noticeable difference, you lose your highway cruising speeds, it all depends on how much that matters to you, you could compromise and get a gsr trans, they are better than the ls's, and have a little better 5th gear for the highway
Old May 24, 2005 | 11:36 PM
EFM_ookie's Avatar
Default Re: what to do??????keep my LS tranny????? (MajorPayne)
thanks
Old May 25, 2005 | 06:46 PM
MajorPayne's Avatar
no problem, but theres a lot more detailed information here in the archives about the differences btw the various transmissions
Old May 25, 2005 | 06:53 PM
Suck my DX's Avatar
are u planning to go n/a or boost...id say a si tranny for n/a and the ls is good for boost..but thats just me talkin
Old May 25, 2005 | 08:08 PM
EFM_ookie's Avatar
Default Re: what to do??????keep my LS tranny????? (AMPYR_one)
im thinkin about boost in the future... im pretty sure im going to keep the tranny for now.. i need to get this car running thanks
Old May 25, 2005 | 08:15 PM
MajorPayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMPYR_one &raquo;</TD></TR><TR><TD CLASS="quote">are u planning to go n/a or boost...id say a si tranny for n/a and the ls is good for boost..but thats just me talkin</TD></TR></TABLE>
well si for na and ls or gsr for boost is the general rule most people follow, the b16 will make you run faster either way, but you can stay in boost longer with the longer gears of the gsr or ls. IMO ls is crap compared to both, but for now it will be fine, but if you really want to get serious, a gsr or si is really the only way to go...shorter gears are always best for running faster times, plus im pretty positive the gsr and si trannies are a little stouter than the ls
Old May 25, 2005 | 10:19 PM
EFM_ookie's Avatar
thanks.. im keeping the ls for now.. i just ordered the hasport hydrolic kit fo r the ef today.... im going to most likely buy a gsr tranny in a couple months
Old May 25, 2005 | 10:35 PM
MajorPayne's Avatar
sounds like a good plan good luck with everything
Old May 27, 2005 | 05:05 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MajorPayne &raquo;</TD></TR><TR><TD CLASS="quote">you lose your highway cruising speeds</TD></TR></TABLE>
VTEC motors do fine with short gearing on the freeway. After all, the ITR has basically the same bottom end as the GSR, yet uses B16A gear ratios. It's only when you mate non-VTEC motors with VTEC transmissions that you have problems on the freeway.
Old May 27, 2005 | 08:14 PM
EFM_ookie's Avatar
Default Re: what to do??????keep my LS tranny????? (StorminMatt)
thanks.. ttt buuump
Old May 27, 2005 | 08:21 PM
MajorPayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
VTEC motors do fine with short gearing on the freeway. After all, the ITR has basically the same bottom end as the GSR, yet uses B16A gear ratios. It's only when you mate non-VTEC motors with VTEC transmissions that you have problems on the freeway.</TD></TR></TABLE>
well i should have been a little more specific, you dont lose your highway cruising speeds, however as you move from an LS to gsr to b16 transmissions, your rpms will be slightly higher at the same mph
Old Jun 2, 2005 | 06:10 PM
EFM_ookie's Avatar
just got my mounts
grnhatch94
Aug 6, 2007 09:33 AM
redDAinteg
May 16, 2005 03:17 PM
ImportsCRX
17
Nov 16, 2004 07:39 AM
fcuk-vtec
Nov 28, 2003 06:39 AM
