Bearing color codes
Old Jun 4, 2006 | 07:18 PM
dohdoh420's Avatar
Default Bearing color codes
hey what do the colors mean? I have heard somthing about the numbers on the crank.. I dont know if these are correct but this is what my crank says across the journals
B1 B2 B2 A2
wich 'colors' do i need?
Old Jun 4, 2006 | 09:09 PM
dohdoh420's Avatar
Default Re: Bearing color codes (dohdoh420)
bump..
Old Jun 4, 2006 | 09:21 PM
Combustion Contraption's Avatar
You need to take those numbers and match them to the block to find out what colors you need. Be sure to measure clearances anyway, when you are done.
Here is the chart.
Old Jun 5, 2006 | 09:42 AM
integra_dude's Avatar
can someone explain how u match em up? i just dont see it
Old Jun 5, 2006 | 01:53 PM
BuddhaSiR's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">You need to take those numbers and match them to the block to find out what colors you need. Be sure to measure clearances anyway, when you are done.
Here is the chart.
These are connecting rod bearing codes for a b18c5 motor.
i dont think he has a type R engine according from the letters and numbers he's got.
You have to get the letters from the block and the numbers from the crank to get Main Bearing code.
For Connecting rod bearings you need the numbers from the Rods and letters from the crank to get Rod bearing codes.
Old Jun 5, 2006 | 05:16 PM
dohdoh420's Avatar
Default Re: (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">
These
For Connecting rod bearings you need the numbers from the Rods and letters from the crank to get Rod bearing codes.</TD></TR></TABLE>
where exactly on the block and crank can these numbers be found
btw: I have a d16y8 block and a d16a6 block those are the blocks I'm looking for bearings for
Old Jun 8, 2006 | 11:21 PM
BuddhaSiR's Avatar
Default Re: (dohdoh420)
there are 5 journals on the crankshaft. there are 5 letters on the block and 5 numbers on the crankshaft. If you look where the sealing surface of the oil pan is, you will find 5 letters. use those letters and the 5 numbers on the crank and you have your bearing codes. I wish i had a pic of the block, so much easier to show someone. The numbers on the crank can be hard to see. The letters go with the journals in a specific order. The letter starting nearest the back of the motor(or flywheel side) goes with the journal nearest the Flywheel. The next letter would go with the next journal and so forth.....
JBLAZE622
Apr 2, 2008 07:14 PM
crxowner
May 10, 2007 11:20 AM
85mm LsVTEC
Feb 19, 2004 07:23 PM
b16vtecsol
10
Jan 10, 2004 11:12 PM
ludesleep
May 10, 2003 08:46 AM
