CEL code 13 with DSM 450's and AFC...help
Old Apr 12, 2004 | 06:47 PM
Iceman05's Avatar
Default CEL code 13 with DSM 450's and AFC...help
i know it's a BARO sensor code, but that's built into the ECU, i cleared it, but it came back.... anyone have suggestions?
Old Apr 12, 2004 | 07:45 PM
d00kee's Avatar
Default Re: CEL code 13 with DSM 450's and AFC...help (Iceman05)
defective circuit or unplugged / defective sensor
Old Apr 13, 2004 | 04:38 AM
EE_Chris's Avatar
Your MAP and BARO sensor are one in the same. When the ECU powers up and does a sensor check, it will compare these two sensor to see if they output roughly the same voltage.....obviously with a AFC installed and fuel correction to boot, the MAP output is already different than the BARO, hence the code.
There is nothing you can do about it but live with it.....if you search, you'll see its a common trend among the 'hack' users.
FSUseminoleEM1
Feb 19, 2010 08:34 AM
njandrewg
Sep 9, 2004 07:12 PM
ILLICON3000
Aug 4, 2004 03:25 PM
kaj
Sep 27, 2003 09:36 AM
