Is Coolant Temp Sensor related to Vtec Engagement?
Old Apr 8, 2004 | 08:18 PM
mikebranson's Avatar
Default Is Coolant Temp Sensor related to Vtec Engagement?
Throwing Code 6 as well as 14. I know what they are, but aside from these two codes, Vtec is not engaging. Oil Level is good, Screen in the Vtec Solonoid is clean..Ran across a thread while searching for info on my cels that mentioned that vtec would not engage if the coolant sensor was bad? Is there any truth in this statement? Thanks for the help..
Michael
Old Apr 8, 2004 | 08:26 PM
redloudlude's Avatar
Default Re: Is Coolant Temp Sensor related to Vtec Engagement? (mikebranson)
for the vtec to engage coolent temp needs to be at 180 this is true
as far as those cels i dont know , your speedo needs to be past 25 mph
for it to work also my car threw a code and vtec dident engage when
my vss broke.
Old Apr 9, 2004 | 08:27 AM
what code were you throwing? so it is a possibilty that w/ the sensor bad vtec may not engage...
Old Apr 9, 2004 | 12:30 PM
SAVIOVEGA's Avatar
Default Re: (mikebranson)
I had the same problem. Wires were hooked up properly, oil was good. But no VTEC. I had a code for Coolant temp. After I fixed that, it worked
Old Apr 9, 2004 | 03:05 PM
sweet.... i'll try a new sensor
Old Apr 9, 2004 | 04:45 PM
SAVIOVEGA's Avatar
Did you test the sensor to see if it is bad. My problem was with the wires to the sensor. One was all chewed up and was only getting 2 volts (it supposed to get 5).
Old Apr 9, 2004 | 06:10 PM
Default Re: (SAVIOVEGA)
i will check that first..
thanks for the info...
Old Apr 9, 2004 | 08:23 PM
X2BOARD's Avatar
Default Re: Is Coolant Temp Sensor related to Vtec Engagement? (redloudlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redloudlude &raquo;</TD></TR><TR><TD CLASS="quote">for the vtec to engage coolent temp needs to be at 180 this is true
my vss broke.</TD></TR></TABLE>
Never heard that... stock coolant temp sensor doesn't detect minor changes in temp... so I don't see how that would help w/ vtec engagement.
The fuel delivery does reference the temp sensor tho....
Old Apr 13, 2004 | 09:00 PM
B18PoweredCivic's Avatar
Sure you dont have the sensors plugged in wrong?
ntoxicatedtigah
Jun 24, 2009 02:56 PM
LsVtakYO
Dec 5, 2005 10:54 AM
vtecpsyco
Oct 23, 2005 11:18 PM
user 72830283
Oct 16, 2005 08:24 AM
jonas
Mar 15, 2003 03:09 PM
